Facing fluids change, some questions. - Page 3 - Suzuki Forums: Suzuki Forum Site
Old 02-16-2017, 10:31 AM   #21 (permalink)
mleindek's Avatar
mleindek is on a distinguished road
Trans is automatic 5 speed, number model I'll found out as soon as I get home, truck is a 2007 V6 2.7 US spec. So far drove 130 miles and not any sympthoms but I'm quite confused with the discrepancy, 1lt is way too much.
I didn't run the engine during the change, I did exactly what the guy in this video does:
https://youtu.be/xH4Epgbisis
mleindek is offline   Reply With Quote Quick reply to this message
Old 02-16-2017, 12:49 PM   #22 (permalink)
mleindek's Avatar
Just checked the service manual again and it, says:
A/T fluid capacity reference value:
When draining from drain plug hole: Approx. 2.5 liters (5.33/4.40 US/Imp. pt.)
When overhauling: Approx. 7.2 liters (15.36/12.67 US/Imp. pt.)
Since I already drove 150 miles and the fluid circulated I'm going to drain it and fill it again to get the most of the old one out, this time I'm going to do what the manual says (2.5 lts) and run it for a few minutes and check but it is possible that for some reason (oil being too old and thin) one more liter came out? That's the only possible explanation that comes to my mind, both user and service manuals can't be wrong.
Old 02-16-2017, 01:11 PM   #23 (permalink)
Patico is on a distinguished road
Those are the same number I have.
Take a good look at the tube where you pour the transmission oil (the same that holds the dipstick). I has an ear that must be bolted to the engine.
In my tracker, that ear was broken, so the tube was not correctly inserted on the transmission. Can't recall if it went too deep, of was not fully inserted. This gave me a wrong reading.
_____________________
Chev Tracker 2001, 2.0 liters
Automatic Transmission
4 door.
Patico is offline   Reply With Quote Quick reply to this message
Old 02-16-2017, 04:07 PM   #24 (permalink)
mleindek's Avatar
Patico, just took a look at the tube with a flashlight and no leaks at all.
Just finished the 2nd fluid change, the one that came out this time was bright red (only one day and 150 miles of use) and almost a gallon (3.3 lts to be exact) came out, again.
Went with the manual and poured exactly 2.5 lts, warmed engine, went for a 10 min ride, measured and oil was lower than the cold mark so common sense says it needed more than the 2.5 lts than the manual says, took me 3 more tries of adding/ driving/ measuring cycle until I got it 3/4 full, ended up using... You guessed it: 3.3 lts.
Don't know why this is happening and I still believe that almost 1 lt is too much of a difference but when I first drained almost 3.5 lts came out so that's exactly what I put back in.
This weekend I have to make a 300 miles roundtrip, I'll let you know on Monday if my transmisison explodes! I'm joking but now I'm a bit worried too, thought it would be a good idea to make the change before the trip, never thought this was gonna come up....
Old 02-16-2017, 09:05 PM   #25 (permalink)
Overfilling can lead to oil foaming, leaks and transmission failure.
Not a good thing.
You know, sometimes manuals have errors. That's something to live by.
Tha manual for the 2000cc, 4 cylinder Tracker states this:
When draining from drain plug hole: 2.5 liters (5.28/4.40 US/lmp.pt.)
When overhauling 7.1 liters (15.00/12.50 US/lmp.pt.)
Perhaps an unchecked Copy-Paste from an older manual???
EDIT:
Found new info
2.5 / 7.2 liters seem to come from the JB416/JB420 manual .These are 1600cc and 2000cc engines.
Check carefully and see ir you are reading from the correct manual for your car.
If it's a PDF file, ckick in FOREWORD. There should indicate the car model.
4 door.
Old 02-16-2017, 09:37 PM   #26 (permalink)
Check what I found in the manual for Grand Vitara JB627
Compare the drawings and see if those match the appearance of your car. This manual states 3 liters for draining and 9.9 liters for overhaul
DIRTY MINDED PEOPLE SHOULD REFRAIN FROM READING THE NEXT PARAGRAPH:
Also, is there a way you can compare your dipstick with someone who owns a similar car??
There was this car whose engine oil dipstick handle broke, and the owner fixed it with epoxy. Then came Patico, bought a new one from the dealership and the epoxy stick reached 1/2" deeper than the original.
4 door.
Old 02-17-2017, 12:12 AM   #27 (permalink)
mleindek's Avatar
Patico you saved my life! Nor the user manual that came with the truck and nor the service manual I downloaded have those pictures or that information. 3 lts sounds WAY more accurate and near the 3.3 that drained out! And yes, the illustrations are of my same exact engine. Don't have the manual in here right now (it's in the truck in the garage and it's kinda late now lol) but tomorrow I'm taking a couple of pics to show you what it says! Probably as you said, a copy/paste from another model :/
Regarding the dipstick comparation I face two problems there, 1- Since Suzuki went out of business in the US this gen of GV is not that common to see around here and 2- I don't imagine stopping another driver and asking him if he doesn't mind comparing the length of our sticks for research purposes rofl!
Hey thanks again, you brought some clarity, I was litetally pulling my hair with this...
