Facing fluids change, some questions. - Page 2 - Suzuki Forums: Suzuki Forum Site
Old 02-09-2017, 02:24 PM   #11 (permalink)
Darrell.'s Avatar
I can't find anything in my workshop manual on the extension case. Maybe only certain countries are offered a 2wd version and my workshop manual is European
1987 SJ413 Rusty tin top, 2005 Grand Vitara 1600se.
Old 02-09-2017, 02:55 PM   #12 (permalink)
Patico is on a distinguished road
Take a good look around the bottom of all transmission parts, looking for drain plugs.
This should give you an idea if you are missing some oil to change.
_____________________
Chev Tracker 2001, 2.0 liters
Automatic Transmission
4 door.
Patico is offline   Reply With Quote Quick reply to this message
Old 02-09-2017, 03:32 PM   #13 (permalink)
Darrell.'s Avatar
By my reasoning I believe you have this..
Old 02-09-2017, 06:33 PM   #14 (permalink)
mleindek's Avatar
mleindek is on a distinguished road
Oh that's a new one! So that's the extension case? Will have to look under my truck and try to identify parts and drain/ fill plugs
mleindek is offline   Reply With Quote Quick reply to this message
Old 02-15-2017, 07:22 PM   #15 (permalink)
mleindek's Avatar
Can someone tell me what fluid this part uses? Already replaced trans fluid and while it may be a bit smoother I didn't notice any other changes, old fluid was brown but no metallic pieces so I guess that's not bad at all.
On a side note I ordered part #09168-12002 which I thought it was the washer for the trans pan but I guess I was wrong... Does someone have the correct part #? I'll be doing another two changes in the following weeks to be sure all the old oil is out.
Old 02-15-2017, 08:58 PM   #16 (permalink)
I presume GL-4 gear oil as a conventional transfer case would use, as there are no hypoid type (differential style) gears employed here.
See also...
http://www.suzuki-forums.com/3g-2006...-case-oil.html
'03 Honda Odyssey
Old 02-16-2017, 07:22 AM   #17 (permalink)
mleindek's Avatar
So I'm a bit confused here...
My owner's manual says my transmission uses 2.5 lts (5 pints) of fluid but when I drained it I got almost a gallon out (3.5 lts maybe), checked level before draining and wasn't overfilled.
Old trans fluid: Almost a gallon
So where's this extra lt coming from?
The extension case says it only takes 0.47lts (1 pint), is that correct...?
Old 02-16-2017, 09:22 AM   #18 (permalink)
What oil retrieval method did you use?
IF just oil from the pan it will be less than if you used the transmission cooler line / trans in operation mode, which the ladder will remove additional torque converter held oil.
'03 Honda Odyssey
Old 02-16-2017, 09:43 AM   #19 (permalink)
mleindek's Avatar
Drain plug from the trans pan, added the same amount and dipstick shows almost full ?
Old 02-16-2017, 10:04 AM   #20 (permalink)
And you didn't RUN the engine in any part of this pan draining evolution?
Verify for us what trans type, number of speeds and model number please.
'03 Honda Odyssey
