I can't seem to find a direct answer to this question, or perhaps not asked properly. I'm looking to identify Bank # and Sensor # for the 4 O2 sensors.
(I've located all 4 sensors)
2008 XL-7 Limited, 6 Cylinders 3.6L MFI DOHC
I believe Bank 1 sensors are PRE catalytic converter and Bank 2 are POST converter. Can this be confirmed?
What I DON'T have a handle on is Sensor ONE vs Sensor TWO.
Are Sensors one in the FRONT of the engine or the rear?
It looks like you are using a real time scanner to look at the oxigen sensors cycles.
If you can't identify them, simply unplug one at a time and look at your scanner, if it's not cycling you can identify it.
THANK YOU....I'm not using a real time scanner, but your protocol would work . Actually feel kinda stupid for not thinking of it, guess its been too long since I've worked on my car and troubleshooting skills are rusty!
Bank 1 & 2 refer to the two banks of cylinders, sensor 1 & 2 refer to the position of the sensor relative to the catalytic converter - sensor 1 is pre-cat, sensor 2 is post-cat.
On the earlier H-series V6 engines (2.0, 2.5 & 2.7) bank 1 was the left bank, bank 2 was the right - I've never looked at the 3.6 so I don't know which is which, but you can identify it by looking to see which bank is closest to the front of the engine - one bank will be an inch or two further forward than the other.
93 - 1.3 Suzuki Swift GLX
98 - 2.0 Suzuki Grand Vitara
Thank you!
RESOLVED (Thanks all!!)
Standing in FRONT of the vehicle, BANK 2 is the front 2 or closest sensors, Sensor 1 is PRE catalytic converter and Sensor 2 is after the CC.
BANK 1 is the far side or closest to the Driver, Sensor 1 is PRE catalytic converter and Sensor 2 is after the CC.
Will a scanner code identify which sensor is bad? Tech at shady dealership told me "bank one, rear" replaced it ( bank one downstream) but CE light still on. Haven't gotten codes pulled yet. 08 xl7, got a bosch sensor.
Reason: additional info
Bank 1 Rear, or downstream would be Bank 1 sensor 2, or on the driver's side of the engine, underneath and after the Cat Conv. a relative EASY replacement, in fact ALL are easy replacements with the exception of Bank 1, sensor 1, nestled down deep by the firewall, a BITCH to get to. But yes, a code checker WILL indicate the senor and bank
