Vibration at Highway Speed - Suzuki Forums: Suzuki Forum Site
Go Back   Suzuki Forums: Suzuki Forum Site > Suzuki Models > 2G (2007+) XL7
Old 10-04-2011, 01:00 PM   #1 (permalink)
BigPaco is on a distinguished road
Default Vibration at Highway Speed
I'm experiencing a bad vibration at highway speeds. It is very evident when the brakes are initially applied at high speed (100+ km/h or 60+ mp/h), like a badly warped rotor, but goes away once the brake pressure increases.
I'm thinking it may be suspension or steering-related such as a ball joint or tie-rod because of how the vibration goes away once the brake pressure is applied. Has anyone else experienced this?
I have all original brakes which I will be replacing soon. The fronts I think are OK (just worn) but the back has a slightly warped rotor.
BigPaco is offline   Reply With Quote Quick reply to this message
Old 10-06-2011, 02:27 PM   #2 (permalink)
Goaterguy's Avatar
Goaterguy is on a distinguished road
I think those still may be symptoms of warped rotors.
2005 GTO PBM M6
2007 Suzuki XL7 Luxury AWD
2006 Aprilia Scarabeo 500 GT ABS+
2007 Roadrunner Classic iscooter "Pinky"
2006 B&S 3.5 hp lawnmower
Goaterguy is offline   Reply With Quote Quick reply to this message
Old 10-06-2011, 08:26 PM   #3 (permalink)
Thanks. I agree and plan to put new rotors and pads on in the next few days. If that doesn't fix it then on to the next possibility.
Old 10-09-2011, 11:28 AM   #4 (permalink)
Replaced rotors and pads Friday but I haven't yet had a chance to take it on a good drive to determine if the vibration is gone. The old rotors were hell to get off due to corrosion on the inside catching on the wheel bearings. I basically had to hammer them off with a BFH. Bearing surfaces were cleaned thoroughly and new rotors and pads installed. Two 18mm bolts hold the caliper brackets on. The top one is difficult to remove and requires that the bracket for the brake hose be removed (13mm).
