Timing chain a problem!! - Suzuki Forums: Suzuki Forum Site
Go Back   Suzuki Forums: Suzuki Forum Site > Suzuki Models > 2G (2007+) XL7
Closed Thread
Old 10-20-2010, 11:16 AM   #1 (permalink)
Rickard is on a distinguished road
Exclamation Timing chain a problem!!
My 2007 XL7 currently has 80 000 KMS or approx. 50 000 miles. My engine light came on a few weeks ago but would only come on for a short time then go off for a period of time. I checked the code and it came up as a P008, something to do with the crank or cam shaft timing. But since the light was not staying on permanently I thought it might just be a problem with the sensor itself. About 2 weeks later the light came on and stayed on. The truck seemed to be running fine and have not noticed any lack of performance. I brought it to the Suzuki dealer this morning to find out that the timing chains need to be changed. I was told that this is a problem/flaw with these motors. The parts have been ordered and my vehicle will be spending 2-3 days next week. This is all covered under the powertrain warranty. I did ask if I should expect the same problem 80 000 KMS later and they said probably not since they are replacing the parts with what is suppose to better quality parts from Suzuki. I am not impressed at all with this problem and I will probably get rid of this vehicle by next year. I have lost confidence with this vehicle!
Rickard is offline   Quick reply to this message
Old 10-20-2010, 12:35 PM   #2 (permalink)
I've never heard of a P008 code.
What or how did they determine that you need chains?? If your engine was properly maintained and treated, that's bunk!
I've got 243,000 miles on mine.
'03 Honda Odyssey
Max is offline   Quick reply to this message
Old 10-20-2010, 04:40 PM   #3 (permalink)
outtolearn88 is on a distinguished road
Default Oooo Ya...???
Hello,
Can you please let us all know how they came up with that...?
Like what did they write on the work order....?
I have never heard of that code either see....
So keep us up to date please.
Thank You.
outtolearn88 is offline   Quick reply to this message
Old 10-20-2010, 10:44 PM   #4 (permalink)
Default timing chain
The code is a DTC P0008 "Engine Position System Performance Bank 1".There are actually 3 timing chains. This code activates if there is a misalignment at an idler sprocket for either bank or at the crankshaft. I believe this problem is only on 2007 and newer XL7's. Apparently there is so much tension on these chains that they do actually stretch which will eventually cause problems so I am told. I will update more when I bring the vehicle in next week. I will ask more questions to find out more about this.
Old 10-21-2010, 04:48 AM   #5 (permalink)
OK, add an extra "0" to the code and it's camshaft related. I understand now.
http://www.suzuki-forums.com/2g-2007...gine-code.html
Still rather odd for a low mileage engine needing chain replacement though.
The problem could just as easily be the CPS (Cam Position Sensor) OR the wiring / connector to it. I wouldn't rule out an ECU issue either.
'03 Honda Odyssey
Old 10-21-2010, 06:06 AM   #6 (permalink)
lumpylarry's Avatar
Yup. They stretch.. I've replaced tons of them. Some less than 40,000 km
If you put the old ones next to the new ones you can actually see about 1/2" difference.
I've seen one get bad enough to skip a tooth!
2008 suzuki SX4 sport sedan 5spd FWD
2007 suzuki boulevard C50 SE
2001 suzuki swift 1.3 5spd blue
lumpylarry is offline   Quick reply to this message
Old 10-21-2010, 06:19 AM   #7 (permalink)
You're kidding! So much so that the tensioners don't accommodate for wear?
Is this excessive stretch phenomenon peculiar to the later produced 2.7's only?
'03 Honda Odyssey
Old 10-21-2010, 08:00 AM   #8 (permalink)
lumpylarry's Avatar
No.. Not the 2.7s..
This is particular to the '07+ xl7 with the GM style 3.6
Old 10-21-2010, 09:36 AM   #9 (permalink)
Wow. Rather discouraging, huh.
'03 Honda Odyssey
Old 10-23-2010, 08:58 PM   #10 (permalink)
Teresadf is on a distinguished road
Originally Posted by lumpylarry View Post
No.. Not the 2.7s..
How do you find out if you have the GM style 3.6? I need to know if I have this problem to look forward to/watch out for, as well. SMH
Teresadf is offline   Quick reply to this message
Closed Thread
