Oil Light Reset - Suzuki Forums: Suzuki Forum Site
Go Back   Suzuki Forums: Suzuki Forum Site > Suzuki Models > 2G (2007+) XL7
Old 02-17-2010, 08:34 PM   #1 (permalink)
radicalrusxl7 is on a distinguished road
Smile Oil Light Reset
Yes how do you reset the oil light sensor after oil change?
radicalrusxl7 is offline   Reply With Quote Quick reply to this message
Old 02-17-2010, 09:42 PM   #2 (permalink)
northeastXL7 is on a distinguished road
Use the center button of the DIC and scroll through until you get to the oil life remaining screen. Then push and hold the checkmark button until it resets to 100%. 2007 MY do not always reset the first time. Repeat the procedure until it resets-this may take several tries. There is not a fix to correct this glitch. 08-09 MY work the first try every time. Also I do not recommend following the OLM percentage-it simply runs the oil too long in this engine and will lead to sludge.
northeastXL7 is offline   Reply With Quote Quick reply to this message
Old 02-17-2010, 10:41 PM   #3 (permalink)
I'll add in case you were wondering - the procedure in the owners manual for 2007 is WRONG. Use what the above poster has said, works.
Jeff L. is offline   Reply With Quote Quick reply to this message
Old 02-18-2010, 11:03 PM   #4 (permalink)
Unhappy
ok i did what you said like 55 times and it did not work
Old 02-19-2010, 12:22 AM   #5 (permalink)
I'm assuming you have an '07 then. Keep tryinh it-it will eventually work. You are probably seeing the percentage blink momentarily while you're doing this-when it finally takes it you will see it blink and then it will display 100%. I know it's frustrating but GM will probably never give us a fix for this. The only other way to do it is to hook up the Tech2 and manually reset it w/ the scan tool.
Old 02-21-2010, 03:37 PM   #6 (permalink)
Goaterguy's Avatar
Goaterguy is on a distinguished road
Yes, set DIC to oil life, press and check mark button until the % flashes and release, if it doesn't go back to 100% press again until it flashes and release. Keep repeating until you get it.
Mine takes about five times but mostly it resets at the first time.
2005 GTO PBM M6
2007 Suzuki XL7 Luxury AWD
2006 Aprilia Scarabeo 500 GT ABS+
2007 Roadrunner Classic iscooter "Pinky"
2006 B&S 3.5 hp lawnmower
Goaterguy is offline   Reply With Quote Quick reply to this message
Old 02-26-2010, 04:45 PM   #7 (permalink)
guxu is on a distinguished road
Faint, I just did that (07 XL7) over the weekend. I followed the owners manual and of course it did not work. I was wondering if that was because I changed the oil before the "Change oil soon" light was on.
I pressed check mark button too and did see the % flashing. Then, somehow, while pushing the gas (following the owners manual) and pressing check mark button, the % suddenly reset.
guxu is offline   Reply With Quote Quick reply to this message
Old 02-26-2010, 08:49 PM   #8 (permalink)
Yea it finally worked for me
Old 08-29-2010, 01:25 PM   #9 (permalink)
Silver 2008 XL7 is on a distinguished road
Smile oil change re-set oil change light to 100%
I reset oil change light by turnung key to on and pumoing break pedel five times. Oil percent came up to 100%.
AL
Silver 2008 XL7 is offline   Reply With Quote Quick reply to this message
Old 02-04-2012, 03:44 PM   #10 (permalink)
lolo7 is on a distinguished road
Thumbs up Finally worked
Had to do it like 15 times. It finally did reset. I also tried the break, but that did not work for me. Thanks!
lolo7 is offline   Reply With Quote Quick reply to this message
