What's the capacity of oil needed? 5 US quarts
Where is the drain plug located? oil pan, rear
Where is the oil filter located? Front of the engine, over the frame. Somewhat difficult to get to, especially if its the first oil change. The factory tightens it too much.
Size of bolt? I think it's 13mm
Now, it looks like you want to do the oil change by yourself, correct me if I'm wrong but your questions are very basic so I will presume you don't have much knoledge related to vehicle maintenance.
I would suggest you to take it to a mechanic on the first oil change and tell him/her to tighten the oil filter by hand (the way it is supposed to be done) and to show you how he does it. You can do the next oil change with confidence.
An oil change is very cheap at most jiffylube like places, hell it cost me more to do an oil change myself than to pay someone else to do it. I do it because I know it's being done right, with the proper synthetic oil and I'm old school with preventive maintenance.
If you decide to change the oil yourself, always loosen and/or remove the oil filter before draining the oil from the engine (be careful not to tear a hole in the filter), this way if you cant remove the filter, you can still drive to a mechanic.
