Go Back   Suzuki Forums: Suzuki Forum Site > Suzuki Models > Suzuki Vitara, Grand Vitara & XL-7 Forum (1999+) > 2G (2007+) XL7
Old 07-01-2008, 11:21 AM   #1 (permalink)
csigala is on a distinguished road
Exclamation What am I missing
I purchased a factory navigation unit off another xl7. When I went to instal the unit, i noticed that I am missing 2 plugs. I have an '08 xl7 which has the single cd player. It has two plugs but the nav unit has 4 plugs plus the gps antenna plug. Need help in finding out what I need to fully connect the factory nav unit into mine. Thanks
csigala is offline   Reply With Quote
Old 07-01-2008, 11:41 AM   #2 (permalink)
oldpapa49 is on a distinguished road
I can tell you one plug..
A 16 pin plug with a Green/White wire which is your VSS wire..
But your major problem will be the plugs to place into the radio..
The other plug you need to research..
But when I get home tonite, I will look thru the plug list and see what the other one does.
Oh.. you will not have voice unless you see a mic in the top bin on roof. Depends on type of bin, with or without sunroof.
I would suggest a 3rd party unit and sell the nav unit you have..
You do not have mics for voice navigation, bluetooth options.
Old
I have a Pioneer Z2 in my XL7 and works great. I can even tell you where to get that VSS wire as well..
oldpapa49 is offline   Reply With Quote
Old 07-01-2008, 11:43 AM   #3 (permalink)
I have already posted that wire..
http://www.suzuki-forums.com/2g-2007...-vss-wire.html
Reason for being old I guess is forgetful
Old 07-01-2008, 11:59 AM   #4 (permalink)
Exclamation
I was thinking that one had to be the VSS wire. I found this off a wrecked xl7It only cost me 100 bucks. I dont think the girl working the counter knew what she was selling me. Anyways, where can I buy the wire? I already printed out your instructions on where to locate the wire in my xl7. I was thinking the other plug might have something to do with the steering wheel controls? I dont have the steering wheel that has the volume controls so I wonder if would work the same without that extra plug?
Old 07-01-2008, 01:43 PM   #5 (permalink)
You might want to go back and do a snip snip and grab the nav ant if you can.. its under the top dash..
I will get you that info tonite after I get home..
Old
Old 07-01-2008, 08:18 PM   #6 (permalink)
Cool
ok, here it is..
other than the gps connector..
The 2 plugs you have are
1:Battery, Front Speakers, Cell Mic, Antenna Enable, and Low Speed GMLAN Serial Data.
2: Remote radio audio signal, Rear Speakers, Radio audio mute..
The 2 you are missing
1 connector with Aux Audio L/R, L/R DVD Audio Sign (hot lead), Remote Infra red signal, Video Briteness, anything for the remote dvd unit.
2 connector with VSS wire Gn/Wh pin 5
Remember the nav and dvd is included with the higher priced xl7.
so,
You only need the vss wire, so grab the wire where i found it, you wont have it like i did not have it.
You can connect a mic to the one plug pin 4and ground lead of mic to pin 5. The color of wires are on the plug
1 RD/WH battery +
2 TN left front spkr +
3 TN right front spkr +
4 GY (no wire now)
5 Bare (no wire now)
6 WH antenna enable
7 PU/WH LED dimming signal
8 BK/WH ground
9 GY Left front spkr -
10 TN/WH right front spkr -
11 NC
12 NC
13 D-GN Low Speed GMLAN serial Data
14 NC
hope this helps
Old
Old 07-11-2008, 11:35 PM   #7 (permalink)
Is it working?
Old
Old 08-08-2008, 09:46 AM   #8 (permalink)
BigPaco is on a distinguished road
For the 2008 XL7, there is unique wiring content on the main body wire harness and I/P wire harness for the Nav radio option. You may be out of luck. I use a Tom Tom in my 2007 XL7.
BigPaco is offline   Reply With Quote
