I am experiencing the exact same humming/roaring sound in my 08 Luxury. I have 42,700 miles so far. I've actually had the noise for a while now but I took it in to have it checked out. Sure enough, the driver's side front bearing is going out
. The dealership is telling me that the rim is bent and that is what caused the failure. I baby this vehicle. I've never hit a curb or pothole with any significance, so I'm not sure how this could of had happened. Anyway, they are still fixing the bearing under warranty. They are also replacing the engine hydraulic damper that a TSB has been issued for (under warranty). Both of these parts have been ordered and will be in next week. I will keep everyone updated as to how this goes.
On another note, I just replaced my tires. It was Suzuki's idea that my tires were going bad and the sound could possibly be because of them. I needed new tires anyway as I still had the originals. It did not fix the problem and is why they finally put the vehicle on a lift and found the bad bearing. I really just wanted everyone to know that I stepped up on my tire size to 235/65/17 versus the factory 235/60/17. It works perfectly and looks much better. I really like the raised white lettering look and larger side walls. Good luck finding a 235/60/17 with raised white lettering. Only issue is the speedo reads 3 mph slower than my actual speed. The suzuki tech says the ECU cannot be reprogrammed with the larger tire size. I smell bull on that one but don't really care because essentially it means my warranty will last longer (in miles) LOL!
