Go Back   Suzuki Forums: Suzuki Forum Site > Suzuki Models > Suzuki Vitara, Grand Vitara & XL-7 Forum (1999+) > 2G (2007+) XL7
Old 02-03-2007, 03:38 PM   #1 (permalink)
littlemo is on a distinguished road
Default Tow Hitch
Has anyone fitted a tow hitch to a 2007 XL7....if so...what make?
littlemo is offline   Reply With Quote
Old 02-04-2007, 07:38 AM   #2 (permalink)
MikeLike is on a distinguished road
I just purchased an XL7 last week. Mine came with an optional hitch package. Unfortunately I do not know the make. I'll try to report back later.
MikeLike is offline   Reply With Quote
Old 02-23-2007, 12:33 AM   #3 (permalink)
STORMCHASERXL-7
Default Tow Hitch
Etrailer has them. I installed the curt Class 2.5 model. It was a pain to get to all of the bolt holes due to the mufflers, but once it was done, it looked good. The next task is the wiring. I found the harness, but they due not have an adapter as of yet. I also found that the harness is dead. It looks like in order to make it active, you must buy a couple of relays for the engine fuse/relay box that are for the left and right trailer stop and turn signals. Maybe the individual that has the dealer or factory installed unit could provide the relay details for us. I have not gone to the dealer, yet. I was going to try the auto parts stores first, knowing that the deal will charge a premium.
2007*Suzuki*XL7*hitch search *by etrailer.com (800)298-8924
Regards,
Ivan,kc5yti
STORMCHASERXL-7 is offline   Reply With Quote
Old 02-23-2007, 11:22 PM   #4 (permalink)
Thanks for the info, I checked it up on line and its just what I need ....and its a lot cheaper than the factory unit.
Old 03-28-2007, 10:37 AM   #5 (permalink)
STORMCHASERXL-7
Smile
Mikelike or anyone with an 07 with the tow package, can you possibly take a picture or get the numbers off of the relay 58 and 59 in the engine fuse/relay box. I have been trying to get these relays from the dealer, but they are having issues figuring out the proper part numbers. These two relays will drive the stop/turn lights for both sides of the trailer. Without them, the harness will not have power for the stop and turn lights.
Regards,
ivan
Old 05-02-2007, 11:57 PM   #6 (permalink)
kas
kas's Avatar
kas is an unknown quantity at this point
The dealer should be able to order you one... My dealer up here has them in their book...
kas is offline   Reply With Quote
Old 07-21-2007, 11:07 PM   #7 (permalink)
mpatter73 is on a distinguished road
Regards,
Ivan,kc5yti
I am getting ready to mount a Reese Hitch to mine and I was looking where to attach the harness and didn't see any easy access, where was the harness located? Did anyone ever find you the relay part numbers? I have been looking around and couldn't find anything related to them but I have not checked with the dealer yet.
mpatter73 is offline   Reply With Quote
Old 07-26-2007, 10:45 AM   #8 (permalink)
benbooone is on a distinguished road
These relays come with the dealer supplied wiring harnes Its all plug and play u can just acess the plug from inside the jack storage area.
I know the price is a rip off as these are $2 omron relays
benbooone is offline   Reply With Quote
Old 07-28-2007, 12:02 AM   #9 (permalink)
STORMCHASERXL-7
I have a feeling that we will be forced to buy the trailering kit for the vehicle. I have tried to hunt down the relays with the dealer, no luck there. I can't find the relay box diagram that I had gotten from the dealer. When I do, I can post the part numbers that I beleive are the relays. I have also been to Jameco, Allied, Mouser, and even Omron's web pages and can't seem to find a relay that matchs the trailering relay. They are SPST relays. The common rail positive terminals our on the drivers side of the relay sockets. The active ground terminal from the flasher is closest to the cab on the passenger side of the relay sockets. The feed terminal that leads to the harness is on the foward terminal on the passenger side of the sockets. The harness itself can be found high up where the jack is stored. Pull the jack, and reach your hand way up, and you will feel it. Relays 58 and 59 are the trailering relays, if I remember correctly. I took matters into my own hands, and built dual relay module with two 12V relays.
Toward Read of the Engine bay
_________
Active Ground |--- ---| Positive Terminal
To Harness |--- ---| Positive Terminal
__________
Regards,
Ivan
Old 07-29-2007, 10:32 AM   #10 (permalink)
The relays are Omron G8VA and come with or without a resistor
