2011 G.V. 4-cyl Intake Mod Q's - Suzuki Forums: Suzuki Forum Site
Old 02-14-2013, 10:50 PM   #1 (permalink)
SiLo is on a distinguished road
Default 2011 G.V. 4-cyl Intake Mod Q's
I was curious as to if you are able to do a DIY intake change out "K&N / Cone filter and or piping add-ons" without easily throwing CEL's
Any suggestions are greatly appreciated
SiLo is offline   Reply With Quote Quick reply to this message
Old 02-15-2013, 12:59 PM   #2 (permalink)
__________
Sorry if this subject has been well covered before, & if it has could someone post a link to something about it I could not work the search engine for this Forum correctly I guess LoL
Old 02-15-2013, 03:03 PM   #3 (permalink)
*Kiwi is on a distinguished road
What are you hoping to achieve?
Doesn't it already have a cold air intake?
*Kiwi is offline   Reply With Quote Quick reply to this message
Old 02-15-2013, 04:26 PM   #4 (permalink)
Default Achieve
I am looking to "Achieve"
1: More air flow than the factory box will allow.
2: Better throttle response.
3: Better MPG.
Old 02-15-2013, 10:00 PM   #5 (permalink)
orangeute338's Avatar
orangeute338 is on a distinguished road
i have the 2ltr with pod filter mounted to the intake. i removed the standard airbox and ducting. pretty easy...only reason why i did it was because car was in an accident and airbox was smashed and was cheaper then getting a new box, i think if you go off road alot or dusty roads the stock setup is best with a snorkle...
orangeute338 is offline   Reply With Quote Quick reply to this message
Old 02-15-2013, 10:15 PM   #6 (permalink)
reg_c is on a distinguished road
3: Better MPG.
in regards to your airbox, its been engineered to allow the right amount of air, etc, etc, a high flow filter (K&N) will help, especially if you keep it clean, off-road/dusty conditions, a snorkel will help immensly
better throttle repsonse and MPG, if you drive a diesel like I do, a Varra tuning chip will give you both, I was amazed with mine (only got it a week ago)
reg_c is offline   Reply With Quote Quick reply to this message
Old 02-15-2013, 11:23 PM   #7 (permalink)
i removed the rear muffler and have the pod filter and fuel trims arnt far off zero in closed loop so it doesnt really make that much difference to the stock mapping ecu can adjust enough to suit. never drove the car stock so cant say if the throttle response or fuel econ is better or not. being na you wont get a major difference, just have to rev the ring out of it to get any power and just accept its a 4x4....or put a turbo on like im about to do
you could remove the second cat which might give it a bit more power but then prob not 100% legal
Old 02-16-2013, 01:02 PM   #8 (permalink)
Thanks Orange for the info, do you have any pics. If so please post them. Also did you receive a *CEL= check engine light after the air box \ filter replacement?
Old 02-16-2013, 06:40 PM   #9 (permalink)
maybe have a pics in my turbo thread search my profile threads. no reason you would get a check light maf just reads airflow and the difference won't be much so will still be within adjustment range which is proven by the fuel trims not being much off zero. to do it I had to grind all the plastic away and just leave the part where the airflow meter is then you can slip a 2.5inch filters over I made a steel adaptor and glued it to the pipe with a mount to the body so its solid then filter clamps to that. you have to destroy the airbox to do it. or another option is buying a weld on maf bung and making new piping out of alloy that's what I'm doing for my turbo conversion
Security Question
