what kind of anti freeze should we use ??? - Suzuki Forums: Suzuki Forum Site
Old 02-10-2012, 07:54 AM   #1 (permalink)
dida76's Avatar
dida76 is on a distinguished road
Default what kind of anti freeze should we use ???
what kind of anti freeze should we use,,.from some links I saw, that the colour it matter . mine is green but I dont know how often should I change the coolant ??
I have 2006 model and I have drive 13k km
dida76 is offline   Reply With Quote Quick reply to this message
Old 02-10-2012, 10:34 AM   #2 (permalink)
XL7Limited's Avatar
use this. I did and it worked perfectly for years now. BUT, I think its too early to be changing your coolant.
Preston Antifreeze
Old 02-11-2012, 07:44 AM   #3 (permalink)
Sigtran's Avatar
Sigtran is on a distinguished road
In general, coolant should be changed every 3-4 years in order to keep the anti-corrosion properties of the coolant.
I guess yor are talking about DDiS (F9Q) engine. If so, Suzuki is recommending their own brand of engine coolant (antifreeze). However, from service manual, I can see following note:
Alcohol or methanol base coolant or plain water alone should not be used in cooling system at any time as damage to cooling system could occur.
Based on the color of your existing coolant (green) most probably you should use ethylene-glycol based phosphate-free coolant.
Sigtran is offline   Reply With Quote Quick reply to this message
Old 02-12-2012, 05:23 AM   #4 (permalink)
dkguffe's Avatar
Also beware that you should NEVER top op the coolant with anything but water!!!
Mixing coolants are a BIG no no.. Even though the color may be the same, it can be a different type, and mixing types can result in jelly blobs forming and clotting your coolant system.
Replacing coolant should always be done with a serious flush with tap water in between coolant fillings.
so.
Drain..
Flush clean water
Drain
Refill with premix solution of new coolant.
Oz. GV 2006 2.7 Prestige
Rocky Road 2" Lift
ProComp MX6 Adjustables
ARB Deluxe Bullbar
9500 Lbs Winch
Optima YellowTop D34
Roof Cage with 4x HID 4"
HID H11 Lowbeam upgrade
OME Front springs +35kg +25mm
Currently 71.000km +7%
Projects: Dual Battery
Old 02-13-2012, 06:58 AM   #5 (permalink)
XL7Limited's Avatar
You can safely add the prestone I linked to any factory coolant.. Done if for years and many cars without any issues
so.
Drain..
Flush clean water
Drain
Security Question
