whining while coasting..auto GV - Suzuki Forums: Suzuki Forum Site
Old 02-25-2013, 07:47 AM   #1 (permalink)
WaZook's Avatar
WaZook is on a distinguished road
Default whining while coasting..auto GV
Hey folks, just a quick question..i recently whipped off the Bighorns because i was able to pick up a super cheap set of new alloys and new highway tyres and (probably due to the newfound silence of the ride!!) have noticed a slight "whine" when i take my foot off the accelerator at higher speeds (80kmhr+). The noise completely disappears when i accelerate again, or even just gently put my foot back on the gas.
Anybody know what this is?...am i dreaming up a problem?...hope i am!
cheers for any advice!
My GV is a 2009 V6, 5 speed auto
Mat
2009 Grand Vitara Prestige V6
245/70/17 Maxis Bighorn 762s...2nd set of highway wheels and tyres
Ironman Lift
ODA underbody plates
Rhino racks, awning and alloy tray
Safari snorkel + pir breathers
Engel portable 56amp battpack w/12V boost charger
GME CB
factory nudge bar with spotties
Alpine deck + amp, Pioneers sub + spkrs
WaZook is offline   Reply With Quote
Old 02-25-2013, 10:26 AM   #2 (permalink)
I'd suspect the rear end, based on that scenario!
What's the gear oil level and when was it last changed?
'99 Grand Vitara JLX, 2.5L V-6, 4WD, 5 spd std, '00 "Limited" leather interior, OE alarm & SAT radio.
'53 Chevy 3100 Pick-up w/327, TH400 trans w/78' Nova rear end.
'72 Chevy Nova. One owner, SB, A/C, power disc/drum & steering.
Nova resto pics
... http://s155.photobucket.com/albums/s...o/1972%20Nova/
Old 02-25-2013, 03:24 PM   #3 (permalink)
*Kiwi is an unknown quantity at this point
Since the noise appears on the unloaded side of the axle gearset (be it front or rear) I think it's not a wear issue. I would wonder if it had anything to do with resonances excited by the the CV joints, given the lift.
Obviously change the oil in both diffs if you're not sure of the condition but I don't think you have anything to worry about.
I'm amazed how small the (aluminum) diff housings are on this full time-4WD generation of the GV. Even the 2WD models seem to have the same small rear diff which has to handle the full load. My first-gen diesel had relatively massive iron diff housings front and rear.
My 2000 Xterra developed a axle gear whine at 15k miles due to Nissan leaving a small quantity of grinding compound in the oil. That noise appeared as a pure ~400 Hz tone at around 55 mph.
2011 Grand Vitara 5-dr 2.4 auto 4WD
*Kiwi is online now   Reply With Quote
Old 02-25-2013, 03:55 PM   #4 (permalink)
WaZook's Avatar
cheers for the replys guys, regarding the oil being changed...as sad as it is im not sure. Its done 80000kms and has always had the factory logbook servicing @ the dealership where i purchased it. Its due for another service soon so ill get it checked out!
Ironman Lift
GME CB
Old 02-25-2013, 04:44 PM   #5 (permalink)
DBO
DBO's Avatar
DBO is on a distinguished road
The diffs in the GV are a hypoid gear design, so due to the constant contact pressure they should be very quiet when properly lubricated and matched. As already suggested, get your diff oil changed first, but I somehow doubt that's your issue since you say that the whine is only under decel. Anyway, if you're still getting significant noise after the oil change, especially only under deceleration, it'll most likely mean that there's uneven contact between the drive pinion and the main gear.
The cause of that could be wear on the gear set itself, or a shift in the contact position due to wear on the pinion bearings. In any case, to get it diagnosed properly, it'll mean that the diff has to be removed, taken apart and then rebuilt. If you're lucky it could mean just a new set of bearings and everything re-adjusted - done. If the hypoid gear set is worn, then you're probably up for both pinion and bevel gear as they will come as a precisely matched pair from the factory.
2010 GV 3.2 Prestige 5dr
Mods so far:
- Factory nudge parsley
- 55W High Beam HID
- Full LED interior globes replacement
- 2-Din GPS / Multimedia system
- Reverse Cam
- Blackvue dr400g-hd ii
- Dual Viar 480C compressors, 5 gallon tank & a Nathan K3LA
- Raised spring kit from Kings Springs
- LED DRL's & Indicators
- 225/60R18 (on-road) / 245/75R16 MT-ATZ (off-road)
- Custom Boot Box / ABR Sidewinder Dual Battery install
DBO is offline   Reply With Quote
Old 02-25-2013, 07:12 PM   #6 (permalink)
Originally Posted by WaZook View Post
Its done 80000kms and has always had the factory logbook servicing @ the dealership...
According to the service schedule they should have changed the diff oils at 15,000 km.
I would not let that go too long. In my experience with a gen-1 GV and a Swift the magnet provided inside the drain plug is far too small to hold onto any significant load of metal particles. I can only assume the gen-2 GV has the same design and you can imagine what those particles will do to bearings.
Old 02-25-2013, 08:36 PM   #7 (permalink)
dkguffe's Avatar
I had a similar whining on mine, judging by your explanation.
Turned out that I had sucked in water in the front diff, and that bearings, pinion and crown wheel were rusted and bust.
$2000.00 repair..
Oz. GV 2006 2.7 Prestige
Rocky Road 2" Lift
ProComp MX6 Adjustables
ARB Deluxe Bullbar
9500 Lbs Winch
Optima YellowTop D34
Roof Cage with 4x HID 4"
HID H11 Lowbeam upgrade
OME Front springs +35kg +25mm
Currently 71.000km +7%
Projects: Dual Battery
dkguffe is offline   Reply With Quote
Old 02-27-2013, 08:08 AM   #8 (permalink)
WaZook's Avatar
$2000.00 repair..
ouch, hoping thats not the case here, ill take it in next week and get it checked out. Got the big Kimberley trip planned for mid year so i need to iron out any and all issues prior to that
Thanks guys
Ironman Lift
GME CB
Old 02-27-2013, 09:48 PM   #9 (permalink)
Kathmanducas's Avatar
Kathmanducas is on a distinguished road
WaZook - I'm in Perth, with 2009 GV V6 also. Mine has had same hint of a whine since I picked it up (approx 75,000k's), but doesn't seem to have gotten any louder in the 10-15k's since then. Shall keep an eye on the feedback you get from dealer, as mine will be heading in for 90k service in about 2 weeks.
Kathmanducas is offline   Reply With Quote
Old 02-28-2013, 10:17 AM   #10 (permalink)
Dugway 52's Avatar
Dugway 52 is on a distinguished road
Our new GV (Gen II 4 cylinder) 2.4L auto (Canada) front, rear and transfer case oil was changed at 5900 KMS. The front and rear diff oil was absolutely filthy, and the magnets had a very large quantity of "fuzz" attached (I always inspect these on all our trucks personally); the transfer case oil looked virgin (absolutely new).
Based on the manufacturer's schedule of 1st change at 15,000 KMS: IMO, this is far and away too long an interval (given the full-time nature of the Zuke's all wheel drive). My front and rear diff change interval will always and henceforth be at 6000 KMS (at the same time as my full synthetic oil change).
The cost of the dealer diff change is incredibly inexpensive (the price of a meal for 2 out) considering the hellacious down-side to a premature differential re-build. Cheap insurance.
Good luck,
Dugway-
1998 Chev Tracker 4x4/lockers (Named: Little Trucky)
2012 Grand Vitara JLX-L lots of goodies (Named: RubySue)
2004 Silverado 2500HD 4x4 G80 lockers (Named: Big Sil)
2005 Outfitter custom fiberglass/aluminum
truck camper (Named: Campy)
Dugway 52 is offline   Reply With Quote
