2006 GV Funky Idling - Suzuki Forums: Suzuki Forum Site
Old 01-22-2013, 12:05 PM   #1 (permalink)
saegen22 is on a distinguished road
Default 2006 GV Funky Idling
After getting off the highway after a 4-hour roundtrip drive. I noticed my 2006 Premium GV idling when stopped in an inconsistent manner. The RPMs dont move up or down more than 100rpms but it is noticeable when you listen to the engine idle. It still starts right up most times, but since this occurred, it has had some trouble starting at running temperatures.
Anyone experienced this before? Thanks
saegen22 is offline   Reply With Quote
Old 01-22-2013, 05:38 PM   #2 (permalink)
DBO
DBO's Avatar
DBO is on a distinguished road
"Funky Idling" .. sounds like a good name for a 70's R&B band
What engine model do you have? Is it the 2.7l V6? If you have an OBD compliant version a good thing to do would be to check for any diagnostic fault codes.
2010 GV 3.2 Prestige 5dr
Mods so far:
- Factory nudge parsley
- 55W High Beam HID
- Full LED interior globes replacement
- 2-Din GPS / Multimedia system
- Reverse Cam
- Blackvue dr400g-hd ii
- Dual Viar 480C compressors, 5 gallon tank & a Nathan K3LA
- Raised spring kit from Kings Springs
- LED DRL's & Indicators
- 225/60R18 (on-road) / 245/75R16 MT-ATZ (off-road)
- Custom Boot Box / ABR Sidewinder Dual Battery install
DBO is offline   Reply With Quote
Old 01-22-2013, 06:17 PM   #3 (permalink)
Yes, it is the 2.7L. My first reaction was maybe an oxygen sensor but I'm not sure. And I am not sure if I have an OBD compliant version. The check engine light did turn on though.
Old 01-22-2013, 06:50 PM   #4 (permalink)
DBO
DBO's Avatar
Yeah, if the check engine light came on, then there should be some diagnostic codes caught in the memory. Although there's a way to read the DTC codes from the car without a scan tool (if it's equipped with a diagnostic connector), it involves shorting a ground wire into the connector, so I'm not advocating that unless you're very keen.
Any auto service centre will have an OBD reader. I'd check with a few in your local area to see if anyone will do a free scan for you (only takes about a minute). At least that way you get some hints on what to look for. The cars are just so complex these days that anything else would be taking a stab in the dark I think.
Mods so far:
- 55W High Beam HID
- Reverse Cam
Old 01-22-2013, 10:00 PM   #5 (permalink)
edsersolis's Avatar
edsersolis is on a distinguished road
This happened to me once, it may be the same issue. Have a look here: http://www.suzuki-forums.com/2g-2006...rd-gv-rpm.html
Suzuki Grand Vitara JB420 2006 Japanese Make
Rigid Industries 30" E-Series LED Light Bar
Rigid Industries SRM2 Diffused
Ironman 4x4 Springs & Struts
Pirelli Scorpion ATR 245/75R16
Custom Made Rock Sliders & Roof Cage
Smittybilt XRC8 Synthetic Winch w/Custom Made Mount
Safari Snorkel
Optima YellowTop D34
ARB CKMA12 Air Compressor
Hi-Lift Jack UTV-424 42"
1-inch Wheel Spacers
Crunch 1400W 4 Ch. Amp
SAS NOS Bazooka 8" 350W
Next upgrades:
Ironman 4x4 Skid Plates
Sparco Pedals
edsersolis is offline   Reply With Quote
Old 01-23-2013, 10:10 AM   #6 (permalink)
Thanks to both of you for the info!
Old 01-23-2013, 10:14 AM   #7 (permalink)
My idling is less sporatic than what your previous post described. The vibrations i feel are very slight, almost unnoticeable, and the engine doesn't feel like it close to turning off. It sounds like I will have to take it somewhere.
Old 01-25-2013, 03:09 AM   #8 (permalink)
Jpaxed06GV's Avatar
Gallery: 4
Jpaxed06GV is on a distinguished road
Have you checked your oil levels? If low drain it, flush it and replace oil and filter.
Black 2006 V6 2.7 GV
ARB Bullbar
King Springs
HERCULES Terra Trac A/W P245/70R16
FTS Underbody Protection Plates
FTS Alloy Strut Brace
B.T.A. Towbar
ProRack Roof Racks
---Fun 4 All---
Jpaxed06GV is offline   Reply With Quote
