Won't Go into gear - Suzuki Forums: Suzuki Forum Site
Old 01-16-2013, 02:30 PM   #1 (permalink)
maxxiss is on a distinguished road
Default Won't Go into gear
I have a 2007 Suzuki Grand Vitara. I have for 5 years now since I bought it last 2008. The issue just started today. I can turn my vehicle on but when I tried to put it in drive it just won't go into gear. I hit the brakes just to make sure that its not a switch or something and the break lights are ok but still it won't go into gear. Any ideas? Is it the break switch?
Thanks.
maxxiss is offline   Reply With Quote
Old 01-16-2013, 04:32 PM   #2 (permalink)
DBO
DBO's Avatar
DBO is on a distinguished road
So you can move it from P to R and N but cannot physically move the lever to the D position? If all of the above is true, what happens when you press the manual override button for the shift interlock?
I've had a quick look at what's involved to get to, or replace the interlock parts and it doesn't look like a fun exercise.
2010 GV 3.2 Prestige 5dr
Mods so far:
- Factory nudge parsley
- 55W High Beam HID
- Full LED interior globes replacement
- 2-Din GPS / Multimedia system
- Reverse Cam
- Blackvue dr400g-hd ii
- Dual Viar 480C compressors, 5 gallon tank & a Nathan K3LA
- Raised spring kit from Kings Springs
- LED DRL's & Indicators
- 225/60R18 (on-road) / 245/75R16 MT-ATZ (off-road)
- Custom Boot Box / ABR Sidewinder Dual Battery install
DBO is online now   Reply With Quote
Old 01-16-2013, 05:13 PM   #3 (permalink)
Thanks for the reply DBO. It won't go to either gear. When I hit the brakes and put it to N OR D or any other options it won't push thru. Its like its stuck in P. I don't want to force it to go to other gears though cause it might damage it more.
Thanks.
Old 01-16-2013, 05:37 PM   #4 (permalink)
DBO
DBO's Avatar
Thanks.
So what happens when you press and hold the interlock bypass button (little black button next to the gear shift) and then try to shift ?
Mods so far:
- 55W High Beam HID
- Reverse Cam
Old 01-16-2013, 05:44 PM   #5 (permalink)
I'm still at work. I'll try i out once I get home and give you the result. Thanks.
Old 01-16-2013, 07:06 PM   #6 (permalink)
When pressing the shift lock button it did engage. Thanks for that info. I really appreciate it. The only strange thing is, if you put it back to P I'm still having the same issue. Instead of just pushing the break to engage you need to press that shift lock button. I think I can deal with this for the mean time but will have to have it check since its still less that 100 thousand miles.
Old 01-16-2013, 07:20 PM   #7 (permalink)
DBO
DBO's Avatar
Yes, the button disengages the interlock manually so you have to press it to get in and out of drive.
Take it to a Suzuki workshop to get it fixed. It could be as simple as a broken interlock cable, perhaps a fuse, switch or solenoid but the process to diagnose and potentially fix it is certainly not trivial from what I've read.
Mods so far:
- 55W High Beam HID
- Reverse Cam
Old 01-16-2013, 09:59 PM   #8 (permalink)
We figured it out. We noticed that there is no shift lock fuse. Me and my brother assumed that it would be the shift lock relay that may be the problem. So we took it out and switch it with the acceleration relay and it worked. My brother just reset the other one and put it back and everything was working the way it is.
Thanks for help.
