Timing belt or Timing chain? - Suzuki Forums: Suzuki Forum Site
Old 06-16-2011, 09:52 PM   #1 (permalink)
Cecu is on a distinguished road
Default Timing belt or Timing chain?
Good morning,
I have been looking all over the net and within these forums as well without finding the answer.
I own a Suzuki Grand Vitara JB 2.0L Manual, it is a 2005 model and it is the 2nd generation model.
VIN: JSAJTD54V########
Engine Code: J20A
and it is a 4 cylinders petrol engine.
Is anyone able to tell me for sure if it has a timing belt or a chain?
The instruction manual does not have this information and the log book mentions that it requires a timing belt change at 105000Kms but the log book is a generic Suzuki one so I can't rely on that.
Many thanks in advance,
Cecu
Cecu is offline   Reply With Quote Quick reply to this message
Old 06-17-2011, 02:13 AM   #2 (permalink)
dkguffe's Avatar
Two Timing Chains for the J20 Engine
Oz. GV 2006 2.7 Prestige
Rocky Road 2" Lift
ProComp MX6 Adjustables
ARB Deluxe Bullbar
9500 Lbs Winch
Optima YellowTop D34
Roof Cage with 4x HID 4"
HID H11 Lowbeam upgrade
OME Front springs +35kg +25mm
Currently 71.000km +7%
Projects: Dual Battery
Old 06-17-2011, 03:23 AM   #3 (permalink)
Thank you very much for the quick response!!
Would it be safe to assume that the timing chains do not require to be replaced unless noisy or loose?
Cecu
Old 06-17-2011, 04:22 AM   #4 (permalink)
dkguffe's Avatar
Cecu
I do not have the proper knowledge to give advice on this, however, I would imagine that the timing chains would not need to be replaced unless the engine itself is worn a lot as well, such as 3 - 400.000km plus.
It's certainly not something to be changed at replacement interval such as timing belts are.
Rocky Road 2" Lift
ARB Deluxe Bullbar
9500 Lbs Winch
Old 06-17-2011, 05:56 AM   #5 (permalink)
Thank you again, much appreciated.
Cecu
Old 06-17-2011, 06:45 AM   #6 (permalink)
dkguffe is correct.
"Chains" are lifetime parts IF properly maintained / properly treated.
I've got 249,961 MILES on mine in a similarly chain designed 2.5 V-6.
Max is online now   Reply With Quote Quick reply to this message
