Dual Battery - Suzuki Forums: Suzuki Forum Site
Old 06-06-2010, 09:45 AM   #1 (permalink)
Zacwah is on a distinguished road
Default Dual Battery
Hey Guys
Just Wondering has anyone been able to fit a second battery under the bonnet
Or anywhere else that isnt in the way and seen.
Cheers,
Zacwah
Zacwah is offline   Reply With Quote Quick reply to this message
Old 06-06-2010, 10:35 AM   #2 (permalink)
Originally Posted by Zacwah View Post
Hey Guys
Cheers,
Zacwah
Not sure about GVs in other coutries, but I'm sure there isn't enoguh room under the hood in a North Amercian GV for another battery. You would have to put it in the rear cargo area in a battery box. Get an Optima battery (sealed) so you don't have to worry about it venting anything into the interior.
Jeff L. is offline   Reply With Quote Quick reply to this message
Old 06-06-2010, 06:40 PM   #3 (permalink)
latif's Avatar
latif is an unknown quantity at this point
There is almost no room for anything else under the hood...even with a J20A powerplant. The only option will be in the trunk. Even if you are thinking of fitting a higher capacity battery in the original position, the space is quite limited.
Please correct me if I am wrong, but wouldn't anything higher than the OEM spec battery be a bit taxing on the alternator....thus might cause an early failure...in theory? Wouldn't this also be having any side effects to the ECU module?
05 Silky Silver
Leather seat
Full HID setup (main/high/fog)
latif is offline   Reply With Quote Quick reply to this message
Old 06-06-2010, 09:20 PM   #4 (permalink)
No and No.
The alternator has essentially two functions - to provide electrical power to operate the vehicle and it's accessories, and to recharge the battery, replacing the energy used to start the vehicle.
A larger battery, by itself, does not change either of these requirements, so there will be no additional load on the alternator. What needs to be considered here is the reason the original poster wants to fit an additional battery - if the reason involves additional electrical load than the alternator may be affected.
With regard to side effects on the ECU - it plays no part in the electrical system of the vehicle, as long as the supply voltage remains within normal operating limits (roughly 10~15VDC), the ECU will function just fine.
Old 06-06-2010, 10:52 PM   #5 (permalink)
dkguffe's Avatar
I have been thinking the same, since I will have a winch on mine soon.
I don't want to put it inside, so I have been thinking about putting "some" batteries under the driver and passenger doors (I can make them fit in on the inside of the chassis rails) I already have an air tank under the drivers side, so maybe I can only fit it on the passenger side.
I will have to make up some brackets and armour so that I will not damage the battery or batteries (what ever I choose) when I'm out and about.
My Winch will draw a max of 500~600 Amps at peak load, and I also want the extra battery for a Fridge.
Oz. GV 2006 2.7 Prestige
Rocky Road 2" Lift
ProComp MX6 Adjustables
ARB Deluxe Bullbar
9500 Lbs Winch
Optima YellowTop D34
Roof Cage with 4x HID 4"
HID H11 Lowbeam upgrade
OME Front springs +35kg +25mm
Currently 71.000km +7%
Projects: Dual Battery
Old 06-07-2010, 04:15 AM   #6 (permalink)
Well i want to put in a Deep Cycle battery and put a dual battery system in.
dkguffe How did u manage to fit the battery under door. Do u custom make a plate or buy one.
Im In Nsw and i have the 2.4l
Old 06-07-2010, 08:29 AM   #7 (permalink)
dkguffe's Avatar
I have not fitted the battery YET... Read my post again...
Anyway, I figured that since I HAVE managed to fit an air tank under the drivers side, It must be possible to fit a battery under the passenger side.
I have a lot more room, since mine is lifted, and I have the sidesteps on it. I have about 20-25cm between the floor of the body to the lowest sidestep bracket. It should be possible to find a deep cycle battery that will fit there, and to make some kind of waterproof battery canister. I was even thinking about installing it in an old ammunition box.
Its all still just ideas in my head, since I'm busy getting bullbar and winch, and also in the middle of manufacturing a really nice roof rack for it..
Once the bullbar is in, I also plan to install a hot water system for shower etc, this will go somewhere inside the engine bay, perhaps in the front of the radiators.
Too many projects, not enough time... But, thats how it is with a hobby...
Rocky Road 2" Lift
ARB Deluxe Bullbar
9500 Lbs Winch
Old 06-07-2010, 07:18 PM   #8 (permalink)
semco's Avatar
Gallery: 3
semco is on a distinguished road
Garage
Ive seen some pal from Malasia fitting extra two batteries in the trunk and having LCD, dish ect...installed on rear door
2007 USDM Suzuki Escudo Salomon Edition Lux 4x4 auto 2.7L V6
2007 EDM Suzuki Escudo Salomon Edition EXL 4x4 auto 2.0L C4 - traded in for 2013 Nissan Pathfinder 3l Cdi 4x4 auto
2010 JDM Suzuki Grand Vitara SZ 4x4 auto 2.7L V6 - traded in for 2013 Hyundai Avante MD 1.8L auto
________________________________
semco is offline   Reply With Quote Quick reply to this message
Old 06-08-2010, 07:47 AM   #9 (permalink)
dkguffe's Avatar
That dude is messy,,,
I want a clean install.. so it looks standard... and no obstruction in the trunk..
Rocky Road 2" Lift
ARB Deluxe Bullbar
9500 Lbs Winch
Old 07-05-2010, 05:11 AM   #10 (permalink)
smickm is on a distinguished road
Found this one...may suit your needs.
Autocraft - Electrical [Suzuki Vitara Dual battery]
I emailed for some info and this was the speedy reply..
We have the battery boxes in stock at $170 which take 3 x 18amp hour deepcycle agm batteries. These sell for $92.00 each. We usually connect them inusing an 175 amp anderson plug so the batteries can be removed at any time.Some people prefer using a strap to hold the battery box in while some wehave welded lugs onto the box and bolted it in place. Cabling is then run tothe front of the vehicle to the main battery using a Redarc electronicisolator, we can supply the Redarc 100amp isolator for $132.00 if required
smickm is offline   Reply With Quote Quick reply to this message
