Old 11-05-2009, 02:13 AM   #1 (permalink)
geevee's Avatar
geevee is an unknown quantity at this point
Default Speaking of Loose Floormats
Currently there's a controversy going on about floormats coming loose and jamming the gas pedal at full throttle on Toyota models. Questions remain whether the problem is really in the ECM.
Anyway, on the GV, the driver's footwell mat is held in place by a single hook screwed into a plastic fitting on the floor under the front of the driver's seat.
On ours, this plastic fitting has pulled out of the square hole stamped in the floor. The result is that the floormat can drift forward, and could cause problems with the pedals.
So far securing this plastic fitting has defeated my fix-it skills.
Does anyone else have this problem, or what can be done about it. I hesitate to replace the part since any new part likely would suffer the same fate.
Vancouver, Canada
2006 Grand Vitara JLX-L
1990 Dodge Spirit
geevee is offline   Reply With Quote
Old 11-05-2009, 04:02 AM   #2 (permalink)
GV88's Avatar
GV88 is on a distinguished road
My 08 factory mats have a Velcro like effect on the back and sticks to the carpet flooring.
2008 5dr 2.4L Grand Vitara Wagon
GV88 is offline   Reply With Quote
Old 11-05-2009, 11:24 AM   #3 (permalink)
annfan's Avatar
So far my plastic fitting is still attached. I have one on the passenger side as well.
geevee, maybe try a larger screw to hold the plastic clip in place? That might expand the clip enough to wedge it into the hole. Or you could make up a small metal plate held to the car with nut inserts (the pop rivet kind) and also use a nut insert to hold the metal hook to the plate. That way its all removable if needed.
There are also these kind of rubber inserts that might work with less fabrication: Well-Nut Threaded Inserts | Emhart.com
You also might use one of those collapsable aluminum drywall anchors of the right size to give yourself a properly threaded insert.
annfan is offline   Reply With Quote
Old 11-05-2009, 01:01 PM   #4 (permalink)
Taras's Avatar
Taras is on a distinguished road
My 2009 GV dont have those hooks at all!
It's not an issue for me since I bought rubber mats from Canadian tire. They do slide forward but I just pull it back once in a while. I doesn't bother me.
Current ride - Black 2009 Grand Vitara JLX-L 3.2L V6, Custom skid plate
Taras is offline   Reply With Quote
Old 11-05-2009, 04:41 PM   #5 (permalink)
I got the hook in hand when I bought my car, dealership said I didnt need it, and I could put it in if I wanted, but didnt have to.
I've never had a problem with the mat moving, it stays nicely in place..
Grand Vitara 2.7 10/2006 Aussie Prestige Version, Swift S 1.5 I4 8/2009.
RR Lift, BOSS 12 level adjustable rear shocks, Pirelli Scorpion ATR 245/70/17
2x 12" Subs in custom near invisible enclosure.
Currently 50.000km
4x4 Accomplishments:
Fraser Island 2009 - Awesome sand driving. GV unstoppable
dkguffe is offline   Reply With Quote
Old 11-05-2009, 09:16 PM   #6 (permalink)
basspaul is on a distinguished road
my hook is metal and all rusted...
basspaul is offline   Reply With Quote
Old 11-06-2009, 12:13 AM   #7 (permalink)
Taras's Avatar
Yeap, happened in my '06 gv. Salt.
Old 11-06-2009, 01:51 AM   #8 (permalink)
geevee's Avatar
Thanks everyone for the tips and comments. I didn't mention that we have the aftermarket Suzuki brand black rubber front floormats. It may be that using them makes it more likely to pull out the plastic fitting.
Vancouver, Canada
1990 Dodge Spirit
Old 11-06-2009, 09:11 AM   #9 (permalink)
CARMAN3756 is on a distinguished road
my 07 reno just has a plastic....had a plastic clip that held the mat back. after reading about GV88 having Velcro on his I think i might get some Velcro and super glue it to the bottom of the mat and see if that will work, yeah a new weekend project.
CopyNProfit is the first collection of actual tested campaigns available to copy
CARMAN3756 is offline   Reply With Quote
Old 11-06-2009, 10:34 AM   #10 (permalink)
Kootenanny is on a distinguished road
Originally Posted by geevee View Post
Currently there's a controversy going on about floormats coming loose and jamming the gas pedal at full throttle on Toyota models...
Sounds like backpedalling to cover faulty ECM issues on Toyota's part to me (or maybe just poor habits on the part of the driver...). C'mon, many of us have been driving for decades in all kinds of vehicles (and in my case anyway, all kinds of junkers with all manner of mats and/or other stuff on the floor), and who's ever had something on the floor jam their throttle full open before? From what I heard about the accident that caused all this speculation, the Toyota in question had things such as a pushbutton ignition (no key) which requires the driver to hold it down for 3 seconds before it'll shut off the engine.
Anyway, as far as the GV mats are concerned...I removed the stock mats very quickly and put in some deep, "dirt trapping" style mats that are quite stiff--I can't imagine them getting pushed up into the footwell unless I'm in a front end collision (and if they ever did, in the GV I can just turn off the ignition with a twist of the key--or even better, just push in the clutch).
Kootenanny is offline   Reply With Quote
