Old 10-19-2009, 09:42 AM   #1 (permalink)
helldamned's Avatar
helldamned is on a distinguished road
Default uhf/cb radio install
picked myself up a gme tx3440 with remote mic controls. and a 3/6db antenna last week. Been reading up on installing it . Most people say run 12v wire from the battery which is what i will do, but some also say even with a pre-tuned antenna u will need to get it tuned. Anyone who installed one on here got any advice??. Was thinking i do some of the install work myself (im fussy with things being done right) But should i maybe get a professional to look it over when done. read around some people say u can damage your cb if its not tuned properly.
Black - 2008 Grand Vitara Prestige JB Type 2 V6 2.7ltr
http://helldamned.com
helldamned is offline   Reply With Quote
Old 10-19-2009, 07:52 PM   #2 (permalink)
you need a SWR meter from somewhere. It sits between you CB and antenna and measures the reflected power coming back from the antenna in case its out of tune.
The tuning of your antenna depends on where / how you mount it, as power easily reflects from metal parts. That being said, you will also get the best tuning from actually putting it on metal... Ideal mounting of a CB antenna is middle of the roof, or on one side, so as to get as close to 1m2 of metal plate at the base of the antenna.
Alternatively, mounting on the bullbar, you may get the similar effect from the hood.
Beware that when adjusting the antenna if needed, SWR must be measured as you plan on using the antenna (dont stand near antenna while testing, as your body will also reflect power..) What I mean is, you need to put the SWR close to the transmitter, and sit inside the car with doors closed while measuring, then, if needed, turn off the transmitter, adjust antenna, and go back inside the car, and test again until best fit is reached.
An SWR meter should be a $20~30 tool, and is always handy to have at hand.
Grand Vitara 2.7 10/2006 Aussie Prestige Version, Swift S 1.5 I4 8/2009.
RR Lift, BOSS 12 level adjustable rear shocks, Pirelli Scorpion ATR 245/70/17
2x 12" Subs in custom near invisible enclosure.
Currently 50.000km
4x4 Accomplishments:
Fraser Island 2009 - Awesome sand driving. GV unstoppable
dkguffe is offline   Reply With Quote
Old 10-20-2009, 05:50 AM   #3 (permalink)
helldamned's Avatar
thanks dkguffe , i think i go pick one up.
