Old 07-01-2009, 12:51 AM   #1 (permalink)
semco's Avatar
semco is on a distinguished road
Exclamation EDM OEM HID headlights
Finally today I competelly finished my HID project - replacing stock US headlights with EDM OEM HID headlights. Pix attached below.
thats what you need:
installation:
Also I have a set of OEM ballasts with ignitors and Philips d2s bulbs which are available for sale now.If anyone wants to get OEM stuff let me know.
Also I have custom made harness which will allow you to run your any HID kit\ballast along with the DRL. Plz lemme know if you need it.
2007 Suzuki Escudo Salomon Edition Lux 4x4 auto
2002 Toyota Rav4 L Impact Sport SE, 4WD auto
2007 Honda Ridgeline RTL 4WD auto
________________________________
http://www.cardomain.com/ride/2971326/1
http://www.cardomain.com/ride/580081/1
http://www.cardomain.com/ride/620488/1
интересное
semco is offline   Reply With Quote
Old 07-01-2009, 05:29 PM   #2 (permalink)
ammx_i is on a distinguished road
Wow good work, but I have some questions.
1.- Do you have to make a hole where the ballast goes? Or is already made?
2.-The lid goes after the light comes into the set?
3.-the leveling headlights motor works on your vehicle?
4..- How much is the cost of that set??
Thanks for your answer
ammx_i is offline   Reply With Quote
Old 07-01-2009, 07:53 PM   #3 (permalink)
wolfwood is on a distinguished road
job welll done mate...
life is an endless book of excitement and surprise...
wolfwood is offline   Reply With Quote
Old 07-01-2009, 09:08 PM   #4 (permalink)
And where did you buy them? I'd be interested in getting a set for my sister's '06 GV. I haven't experienced anything shitty at ngiht then her headlights. My Acura TSX headlights don't even need to have the hi beams switched on most of the time lol!
Old 07-01-2009, 11:35 PM   #5 (permalink)
semco's Avatar
Thanks guys. It took almost 4 months before I put my hands on it.
1. No. The EDM (European) headlights go with the centre hole already made. Before I was sealed it with the scoutch tape, thats a reason why the hole is not clean.
2. Yes. Everything is watertight now. Also it is quite easy to replace the bulb if it will burn out.
3. No, I didnt buy them and didnt installed. There are few reasons why I didnt do that. First, it costs a little bit high if you take a whole set including harness and second, the sensor goes under rear suspension and for me it is quite tough to do it, so I just aimed lights properly at the dealer and thats it.
4. In total I spend $2.500 more less and 3 months waiting time.
Headlights I bought in Europe, HID ballast and hardware came in from Japan because they are less expensive over there, also I didnt want to have RHD (Japanse) headlights.
Next step is installation my tireless kit. Bumper is already painted and polished, and I gonna pick it up tomorrow and then will need to install the door shell and paint it. Thinking I`d be done till the end of July, because my body shop is quite booked right now, then - show time
FYI: the other OEM HID ballast and ignitors I have dont have rubber seals, so you will need to order it. They cost not so expensive, however you might live with out them.
интересное
Old 07-02-2009, 04:28 AM   #6 (permalink)
latif
Wow!!!!!!
$2,500 for the conversion??????
IF not for the DRL, it would almost be a "plug and play" affair. I only spent about US$300.....for the total full HID set up....comprising of main, high and foglight/floodlight.!!!!!
Ciao!
05 Silky Silver
Leather seat
Full HID setup (main/high/fog)
latif is online now   Reply With Quote
Old 07-03-2009, 06:33 PM   #7 (permalink)
semco's Avatar
well, it is OEM vs afternarket, and OEM all the time costs much higher.
интересное
Old 07-03-2009, 06:56 PM   #8 (permalink)
Is a great set, but a bit expensive, always OEM is better, congratulations semco good job
Old 07-04-2009, 12:47 PM   #9 (permalink)
latif
I am highly confident that the result of my aftermarket conversion IS as good as the OEM. The most common mistake which car owners made are;
1) using incorrect fittings (e.g putting in H3 bulb in a reflector designed for H7) ...different fitment have different "centre of light" !!!!!
2) not adjusting the light beam after the conversion or even after any bulb change.....causing dark spots and/or glare to other road users.
3) MOST people tend to believe that the kelvin ratings (which indicates the color tint) is indicating the brightness!!!!! Higher Kelvin (K) ratings mean darker light colors. Try not to go beyond 5000K or 5500K.
Ciao!
05 Silky Silver
Leather seat
Old 07-06-2009, 05:20 PM   #10 (permalink)
ginegog is on a distinguished road
Ciao!
One more thing Latif ...
If you look at the pictures of the installed OEM housing you will notice that there is a black "patch" on the lower edge which is more easily visible on the high beam side as the HID bulb is on. That anti-reflective coating helps prevent you from dazzling the other road users ... it is not on the standard (halogen) version. The standard housing with the standard halogen bulb will produce a reflection from this part as well but as it is dimmer than an HID it is not as severe.
All, remember (as per Latif's point 2) that in doing an HID or any other light upgrade that there will be other people on the other side of that beam.
ginegog is offline   Reply With Quote
