Old 07-06-2009, 06:44 PM   #11 (permalink)
latif
I have to admit, that matte black painted lower part of the headlight is the only difference between OEM and non OEM. I am also planning to open it up and have that part painted......as soon as I can find a replacement plastic lens.....as mine had started to turn a bit yellowish.
Ciao!
05 Silky Silver
Leather seat
Full HID setup (main/high/fog)
latif is offline   Reply With Quote
Old 07-08-2009, 10:10 AM   #12 (permalink)
mge_1's Avatar
mge_1 is on a distinguished road
Nice! Good job.
Marc Enriquez
www.mgehomes.com
mge_1 is offline   Reply With Quote
Old 09-14-2009, 04:48 PM   #13 (permalink)
luchobe is on a distinguished road
Originally Posted by latif View Post
Wow!!!!!!
$2,500 for the conversion??????
IF not for the DRL, it would almost be a "plug and play" affair. I only spent about US$300.....for the total full HID set up....comprising of main, high and foglight/floodlight.!!!!!
Ciao!
HI, wich one u use??? i want to chage the lights of my gv! I saw this ones REAL PHILIPS 9006 6000K HID KIT *no error codes ultinon:eBay Motors (item 400069042514 end time Sep-21-09 12:17:41 PDT)
, im planning to buy for the Headlamps 6000K H7 Kit and for the fog lamps 3200K H11 Kit, Im rigth??? but I dont have fog lamps Now!, I have to buy the case or the housing? what you recomend me. ????? and whats the diferences with the bixenon.... I prefer to have the High and low in xenon
thanks for your time!
luchobe is offline   Reply With Quote
Old 09-14-2009, 05:40 PM   #14 (permalink)
semco's Avatar
semco is on a distinguished road
Hola Amigo, for the low I would suggest you to have 4300K, this is the OEM and max of light output on the road.
3200K is yellow, so for fog it will work, however as I would be you living in Bogota, I will use H9 halogen bulbs, They produce 2200lumens, it is almost the same as 3200K HID. For your high beams you might install separate HID kit or retrofit your headlights with Bi-xenon projectors then you will have HID on low, HID on low and high + halogen on High. Roughly for Bi-xenon you are looking around $600 to spend only for parts. You can also retrofit xenon projectors on your high`s, the lexus projectors will work fine. If you need advice check out my cardomain pages about retroffiting or ask questions.
You have a choice go with HID kits or OEM. Note: OEM wont work with your HID kits, so before buying something make sure you know what do you want.
2007 Suzuki Escudo Salomon Edition Lux 4x4 auto
2002 Toyota Rav4 L Impact Sport SE, 4WD auto
2007 Honda Ridgeline RTL 4WD auto
________________________________
http://www.cardomain.com/ride/2971326/1
http://www.cardomain.com/ride/580081/1
http://www.cardomain.com/ride/620488/1
интересное
semco is offline   Reply With Quote
Old 09-15-2009, 07:37 PM   #15 (permalink)
Hi friend, I want the fogligths in 3200k for the fog but i dont know the diference between h7 or h9, I dont have anything installed... they didnt came factory. What should I put?
And for the higs where I can see pics of the bi-xenon projectors retrofit? Its hard to do? wheres your car domain?
Thank you for your time!
Old 09-15-2009, 08:05 PM   #16 (permalink)
semco's Avatar
check these links for projectors:
ser02rav4's 2003 Honda Civic on CarDomain - Page 3
ser02rav4's 2003 Honda Civic on CarDomain - Page 4
ser02rav4's 2002 Toyota RAV4 on CarDomain - Page 3
Difference betwen halogen and HID buls is huge, however your fog lights run h11 bulbs. H11 is almost the same as H9, however the lightoutput from h9 is much better: 2200 lumen vs 970 lumen, which is equal to 3200K HID bulb. You will need just cut small little plastic inside the plastic holder and you will have almost the same output like HID with out spending lots of $$. Espesially HID wont work in fogs.But is it your choice of course.
To install HID bi-xenon projector you will need to bake your headlights at 325 degree and open them up, after you switch projectors which would be also custom made, meaning you have to be handy, you bake them again and seal it. After you do aiming. Not too hard job if you know how to do it be carefull, dont overbake them otherwise you will spend $$ for buying new set.
For fog lights you need to buy fog kit, then do installation (work for 5 mins). make sure you have fog light harness on your car first.
интересное
