Old 01-16-2009, 12:25 PM   #1 (permalink)
lhyx is on a distinguished road
Default Did anybody here programmed their Smartpass Key Fob?
Hi to all,
I just want to know...
If you can give tips and suggestions
Thank you in advance!
2006 GV Lux 4X4
2007 Yamaha R6
lhyx is offline   Reply With Quote
Old 01-16-2009, 11:40 PM   #2 (permalink)
geevee's Avatar
geevee is an unknown quantity at this point
Registration Procedure for Remote Controller ID Code.
Note
It is possible to register up to 4 remote controllers in keyless start control module.
Setting keyless start control module to ID code registration mode of remote controller will erase all remote controler ID codes that have been registered in keyless start control module. Therefore when registering remote controller ID codes in keyless start control module, have all of those to be registered ready and execute their registration at the same time.
When registration of more than four remote controller ID codes is attempted, only the last four to be registered will retain their registraion.
In case of vehicle equipped with immobilizer control system, when keyless start control moduel which was used in another vehicle has been installed, it is necessary to perform both registration of remote controller ID code in keyless start control module and registration of ignition key transponder code in ECM. For registration procedure of ignition key transponder code, refer to "Registration of the Ignition Key: in Section 10C"
If remote controller or keyless start control module is replaced with a new one or additional remote controller is necessary, register ID code(s) of remote controller.
1. Sit in driver's seat and close all doors.
2. Check that door lock of driver seat is unlocked.
3. Insert ignition key (1) into ignition key cylinder.
4. Perform steps a) through f) described below within 25 seconds after Step 3.
a) First push manual door lock switch (2) toward unlock side (4).
b) Repeat Step a) 2 more times.
c) Push lock side of manual door lock switch.
d) Remove ignition key from ignition key cylinder once and then insert it again.
e) Repeat Step d) 3 more times.
f) Start engine and wait for 3 seconds.
5. Turn ignition switch to OFF position. When ignition switch is turned to OFF position, buzzer sounds twice and door lock is activated from lock position to unlock position. This operation indicates that keyless start control module has entered registration mode.
6. Push lock or unlock button of remote controller within 30 seconds after Step 5) to be registered. When lock or unlock button of remote controller is pushed, buzzer sounds twice, door lock is activated to lock position and then to unlock position. This operation indicates that remote controller ID code has been registered in keyless start control module. If an additional remote controller needs to be registered, repeat the procedure of Step 6) within 30 seconds after Step 5).
7. To end registration mode, remove ignition key from ignition key cylinder or turn it to ON position. In case of vehicle equipped with immobilizer control, system, if engine start function of keyless start system does not work after registration, check ECM if DTC P1615 is detected. If it is detected, go to "DTC P1615: Steering Lock Control Communication Error (for vehicle with Keyless Start System): in Section 10C". If it is not detected, perform registration procedure again.
Vancouver, Canada
2006 Grand Vitara JLX-L
1990 Dodge Spirit
geevee is offline   Reply With Quote
Old 01-17-2009, 09:03 AM   #3 (permalink)
Thank you Geevee!
It seems hard but I will try...
2006 GV Lux 4X4
2007 Yamaha R6
Old 11-07-2009, 12:13 PM   #4 (permalink)
rook is on a distinguished road
Default remote vs. chipped key coding
In case of vehicle equipped with immobilizer control system, when keyless start control module which was used in another vehicle has been installed, it is necessary to perform both registration of remote controller ID code in keyless start control module and registration of ignition key transponder code in ECM. For registration procedure of ignition key transponder code, refer to "Registration of the Ignition Key: in Section 10C"
I do have an immobilizer. I can program the remote controller, do I need to do anything to program the chip in the cut-hey so that the immobilizer recognizes it??? Or does this procedure ensure that both the remote controller and the chipped key is recognized? Much appreciated.
Is there a procedure to run through for, DTC P1615, or does a dealer need to clear the fault and program with computer?
rook is offline   Reply With Quote
