Old 03-01-2008, 05:53 AM   #1 (permalink)
NC_State_Alumnus's Avatar
NC_State_Alumnus is on a distinguished road
Default ATF fluid drain and fill on a 5 speed
Anybody know how much fluid will come out if i pull the drain plug? also where is a good place to get mobil 3309 atf or toyota T-IV?
NC_State_Alumnus is offline   Reply With Quote
Old 03-03-2008, 06:44 PM   #2 (permalink)
Axe Man is on a distinguished road
I'm also curious to know how many quarts will drain out.
As far as a source for Mobil 3309 ATF look here....
Mobil ATF 3309 Case of 12 quarts
2007 GV 4WD
Axe Man is offline   Reply With Quote
Old 03-16-2008, 03:08 PM   #3 (permalink)
ffej_jeff is on a distinguished road
The FSM says 2.5 litres will come out the drain plug, but the capacity is 7.2 litres.
ffej_jeff is offline   Reply With Quote
Old 07-04-2008, 01:32 PM   #4 (permalink)
I'm reviving this old thread with an info update.
I did a 15K mile drain and refill of the automatic transmission. 3.9 US quarts came out via the drain plug. Refilled with Mobil 3309 ATF.
2007 GV 4WD
Old 07-04-2008, 01:46 PM   #5 (permalink)
RAYSGV's Avatar
RAYSGV is on a distinguished road
Is anyone out there using anything besides the Suzuki ATF and Mobil 3309? Is the Mobil 3309 same as Suzuki ATF or better? Looking to go to synthetic. Does this transmission have a filter?
RAYSGV is offline   Reply With Quote
Old 07-04-2008, 02:13 PM   #6 (permalink)
See my responses in your thread concerning synthetic fluids.
I'm not sure if this transmission has a "true" filter or not. Older Aisin-Warner automatics had a screen type filter that was generally not changed unless the unit required a rebuild.
2007 GV 4WD
