Does anyone know if fitting larger 17" tires to the stock wheels will create problems with the ABS or differentials in case the standard 225/70R16 spare has to be fitted due to a flat??
Basically, the standard ground clearance for the GV is 7.9 inches. The Rocky Road Lift Kit adds 2.125 inches; giving a total of 10.025 inches clearance with the stock 225/65R17 tires.
Going to 245/65R17 increased height by .51"+10.025"=10.535" total clearance
255/65R17 " " " .77"+10.025"=10.795" " "
265/65R17 " " " 1.02"+10.025"=11.045" " "
I would really like to use the existing spare tire & hard cover, but I don't know if it will work with any of the larger tire sizes.
Any help will be appreciated.--- I made a calculation error in my original numbers, these should now be correct.
