Expat,
it is not as simple to install as my "AUX" adapter cable
, but if you are handy with a screwdriver it's pretty straight forward.
The adapter plugs into the back of the stereo and is powered through the DIN cable supplied.
The hardest part is removing the trim from the left and right side of the center console.
- Do not stick a screwdriver between the dash and the trim, open the lower cubby hole lid and you will find an open gap between the console and the trim. You can lift the trim from this point without marring the edges.
-remove the 8 screws that hold the radio/heater assembly to the console and pull the assembly forward far enough to gain access to the back of the radio.
-Plug the supplied cable into the square DIN socket on the back of the stereo and run the cable over towards the glove box.
-reinstall the stereo/heater assembly and carefully pop the silver trim back into place. The trim has to be hooked in at the top before snapping it in down towards the shifter.
-Remove the glove box door, connect the DIN and iPod cables to the control box and find a spot to tie wrap the control box up under the dash. Make sure that the box and cable will not bind on the glovebox door.
-Run the iPod cable out the glovebox opening and reinstall the glovebox door.
Your done
The supplied cable is long enough to reach the back of the vehicle, so there will be lots of cable to tie up out of the way.
You can route the iPod cable into the cubby hole of the center console and keep the iPod in there if you want, or just leave it in the glovebox.
Cheers,
Tim
