I want to thanks all of you that provide the info to make the AUX cable or connector on the Suzuki without it for listenning electronic players.. They sell that connector for 60$ canadian here and it was a 0¢ cost if you have some electronics garbages in your closet.
For the connector, I used an internal USB that fit on PC Motherboard
Ok, it don't fit, but I cut it whit a Dremel cut off disk on the side that one hole is missing and after the cut, it fit like a papa in a mama.
For the wiring, we have to jump trigger 1 and 2 with a 1.5K/Ohm resistance
the color code is brown, green, red, silver
For the 1/8" connector, the left channel is always in the center on the soldering side, it's the tip at the other end.
Same thing if you prefer to put a female one and make a hole beside the radio just like in the 2010 model.
A special thanks to TimMcabe and onglipo to help our communities to bypass a stupid 2000's years engeneers decision or financial departement ?
Hope that can help.
Stef
