Help Hard Shifting? - Suzuki Forums: Suzuki Forum Site
Old 03-27-2011, 03:20 PM   #1 (permalink)
Bigman is on a distinguished road
Default Help Hard Shifting?
Hey guys, I got my new motor in, it sounds great and runs strong but now my 02 v6 auto Tracker shifts hard from park to drive or reverse. It also makes a noise on the down shift at about 15mph. Once moving it shift harder but not as hard like from park. Where is the kick-down cable and what should i use when i change my tranny fluid? I originally thought it was the computer relearning but its been 2 days and 40 miles. Thanks for the help.
Bigman is offline   Reply With Quote Quick reply to this message
Old 03-28-2011, 12:25 AM   #2 (permalink)
Update, I found the kick-down cable. When i pull the cable it springs back so i dont think thats the problem.
Old 03-28-2011, 06:55 AM   #3 (permalink)
Big! Same trans that was in there prior to the engine swap?
If so, I'd double check all of the interconnecting tranny wires / plugs for cleanliness and contact.
'03 Honda Odyssey
Old 03-28-2011, 08:59 AM   #4 (permalink)
Same Tranny, i will check wiring.
Old 03-28-2011, 09:34 AM   #5 (permalink)
After that, I'd look for and dump any codes off a computer scan. Then it wouldn't hurt to disconnect the battery for a few to re-boot the ECU. It does have an ECU to TRANS interface built into it.
'03 Honda Odyssey
Old 03-28-2011, 10:29 AM   #6 (permalink)
As far as the codes wouldnt i have a check engine light or some warning on the cluster? I dont think im pulling any codes. I might just change the fluid but whats the chance of this happening right at the time a new engine gets put in.
Old 03-28-2011, 10:39 AM   #7 (permalink)
aquanaut20's Avatar
Did you have any issue inserting the Torque converter??
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 03-28-2011, 11:04 AM   #8 (permalink)
It depends on the code / fault. SOME codes trigger the CEL right away, while others require several repetitive triggers. They would be on the scan regardless though, either in active or history.
It points to SOMETHING not reattached or adjusted properly, given that all was presumably well from the get-go. But there IS always a coincidence failure against you too.
'03 Honda Odyssey
Old 03-23-2013, 11:59 AM   #9 (permalink)
suzuki boyz is on a distinguished road
I am having the same problem that I cannot figure out. I changed the transmission fluid, transfer case fluid, and front+rear diff fluid. i know the post is a bit old but did you ever solve this particular problem?
suzuki boyz is offline   Reply With Quote Quick reply to this message
Old 03-23-2013, 12:09 PM   #10 (permalink)
The original post discussed after engine swap problems. You'd be better off starting your own thread with all of the pertaining info included.
'03 Honda Odyssey
