H25a (V-6) Engine removal / replacement... - Page 5 - Suzuki Forums: Suzuki Forum Site
Old 12-17-2016, 09:54 AM   #41 (permalink)
beagle..t is on a distinguished road
it says you have to, to pull it but you don't need to to put back in, I didn't have to when I did the swap and easy to take exhaust manifolds off
2002 tracker 2 door with 2.7-V6 swap custom winch bumper 2"bl, 2"coil spacer, 5:12 swap locking hubs and 30x9.5x15
beagle..t is offline   Reply With Quote Quick reply to this message
Old 12-17-2016, 10:16 AM   #42 (permalink)
I don't understand what you are saying.
Some sentence structure would help to.
'03 Honda Odyssey
Old 12-17-2016, 11:19 AM   #43 (permalink)
lumpylarry's Avatar
Steering rack can stay.
I've even left the diff in many times.
Just unbolt the shaft and 2 mounts.
It will slide forward and hang from the axles giving enough oil pan clearance to move the engine forward and up.
Have you taken the diff out yet?
There's a trick before you start unbolting stuff.
2008 suzuki SX4 sport sedan 5spd FWD
2007 suzuki boulevard C50 SE
2001 suzuki swift 1.3 5spd blue
Old 12-17-2016, 11:57 AM   #44 (permalink)
to pull the motor out the FSM says you have to drop the front diff to remove the motor. but to put it back in you don't have to unbolt(remove) front diff. I didn't unbolt (remove front diff when I installed a 2.7 in my 2002. its is easier to just unbolt exhaust manifolds because there isn't enough room with steering shaft to put back in its very tight with the exhaust manifolds on
Old 12-17-2016, 12:35 PM   #45 (permalink)
The front diff is still untouched.
You're saying disconnect the prop shaft and both diff assembly mounts, then slide the entire diff assembly forward and let it hang from the axles. Correct?
Leave the axles attached then?
Column to rack steering shaft stays in place too?
What's this trick Larry?
It sounds crazy to attempt to remove the exhaust manifolds Beagle.
Engine clearance appears OK and I've read nothing suggesting their removal.
'03 Honda Odyssey
Old 12-17-2016, 01:01 PM   #46 (permalink)
removing exhaust manifolds makes it easier to get motor back in, it was for me but I had no help
Old 12-17-2016, 01:47 PM   #47 (permalink)
lumpylarry's Avatar
I've never taken off manifolds or steer shaft.
You doing this on a hoist or the ground?
That would determine if I'd suggest pulling the diff right out..
Old 12-17-2016, 01:51 PM   #48 (permalink)
lumpylarry's Avatar
And for the radiator, don't fight with the lower rad hose.
Just unbolt the pipe at T-stat housing.
2 bolt that hold fuel line and one at the bottom
It all come up together.
Old 12-17-2016, 01:55 PM   #49 (permalink)
ground with cherry picker
Old 12-17-2016, 02:05 PM   #50 (permalink)
lumpylarry's Avatar
In that case I wouldn't completely remove the diff.
Just do like you described above. Obviously the little rubber feed hose needs to come off too
If you do want to remove completely,
Step 1. Pop the passenger cv out of the diff and tie a rag or something in the gap so it can't pop back in. If you move anything else or if it pops back in, you never get apart without breaking the circlip.
Don't know they do this, it's the only car I've seen this happen to,
But I just learned that if you do it first it comes out so easy.
Once that's done, then I would unbolt the drivers side axle, prop shaft and mounts.
Then grab the diff and slide off the passenger shaft.
Note, both axle stay in the car.
