How to replace oil pan gasket on 02 xl7? - Suzuki Forums: Suzuki Forum Site
Go Back   Suzuki Forums: Suzuki Forum Site > Suzuki Models > 1G (2001-2006) XL-7
Old 10-22-2012, 02:47 AM   #1 (permalink)
jonijesjusja is on a distinguished road
Default How to replace oil pan gasket on 02 xl7?
Need a step by step instruction with diagram on how to replace oil pan gasket. I am not a mechanic so any tips would help. Thanks in advance.
jonijesjusja is offline   Reply With Quote Quick reply to this message
Old 10-22-2012, 09:57 AM   #2 (permalink)
There is no oil pan gasket on an XL-7, and if you're referring to the engine oil pan, and you're not a mechanic, I would suggest you not attempt this one on your own.
Is your XL-7 4WD?
If it is, the front axle is under the oil pan and you will need to either drop the axle or lift the engine.
Another thing to be aware of - the oil pan rarely leaks, unless it has been disturbed - if you have what you feel is a leaking oil pan gasket, it is more likely to be oil leaking higher up and running down & back.
Old 10-22-2012, 12:45 PM   #3 (permalink)
It's a 4WD. If not the oil pan, where else can the engine oil leak come from?
Old 10-22-2012, 12:55 PM   #4 (permalink)
Oil obeys the laws of gravity, oil leaking from any joint above the oil pan will run down and appear to be a leaking oil pan gasket - a leaking rear main or crankshaft front seal, a loose oil filter, a leaking oil pressure switch, leaking valve covers, the list is endless, and so far, not specific to the Suzuki H27A engine that you have.
H series Suzuki engines also have their own quirks, there is an upper & lower oil pan, and a two piece block assembly with O rings between the two parts of the block and also between the block & the upper oil pan - whilst it would be unfair to describe these as known problems, they do give trouble if disturbed, as do the timing covers - in fact Suzuki has a TSB out on resealing these engines and warns that what may appear to be a leaking timing cover, is often oil leaking and running down.
What needs to be done is a thorough cleaning of the underside and then observation to find the source of the leak.
Old 10-23-2012, 03:30 AM   #5 (permalink)
What's the best way to clean the underside to find the source of the leak?
Also this leak started after I took it to Pepboys to get the EGR valve replaced. What are the odds?
Old 10-23-2012, 08:21 AM   #6 (permalink)
XL7Limited's Avatar
try taking it back to Pep boys and complain to the manager. I can't imagine what they did up top of the engine where the egr to cause an engine oil leak
Old 10-23-2012, 08:39 AM   #7 (permalink)
You'll need to get the car on a hoist - or at the very least - ramps, spray on degreaser and a garden hose. I would suggest not using a pressure washer, or if you do, don't go from above with the pressure washer - the electrical connectors are splash resistant but not waterproof.
Old 10-25-2012, 06:01 PM   #8 (permalink)
I did and they said they did not cause the leak
Old 10-25-2012, 06:03 PM   #9 (permalink)
Do you have diagrams that I can follow and use as a guide?
Old 10-26-2012, 09:25 AM   #10 (permalink)
XL7Limited's Avatar
honestly I would not attempt removing the pan if you have never did it before..
