2002 Suzuki xl7 2.7 v6 - Suzuki Forums: Suzuki Forum Site
Go Back   Suzuki Forums: Suzuki Forum Site > Suzuki Models > Suzuki Vitara, Grand Vitara & XL-7 Forum (1999+) > 1G (2001-2006) XL-7
Old 03-20-2012, 08:16 AM   #1 (permalink)
alguy is on a distinguished road
Default 2002 Suzuki xl7 2.7 v6
Hello can anybody tell me if this is a free spinning engine or a Interference??? Please
alguy is offline   Reply With Quote
Old 03-20-2012, 11:05 AM   #2 (permalink)
Interference. Why? Do you have "issues"?
'99 Grand Vitara JLX, 2.5L V-6, 4WD, 5 spd std, '00 "Limited" leather interior, OE alarm & SAT radio.
'53 Chevy 3100 Pick-up w/327, TH400 trans w/78' Nova rear end.
'72 Chevy Nova. One owner, SB, A/C, power disc/drum & steering.
Nova resto pics
... http://s155.photobucket.com/albums/s...o/1972%20Nova/
Old 03-20-2012, 12:00 PM   #3 (permalink)
Thank you......Yes I do..........A No start.......Just like a Timing Chain issue.....any suggestions??? I put it in Garage before went on Vacation....When came home...went to remove from Garage.....Turned vehicle over and didnt start...Tried again and No start just the exact noise a Timing chain does....Has 90,000 miles never had issues..any Suggestions???
Old 03-20-2012, 12:08 PM   #4 (permalink)
Gotta' figure out if it's no fuel or no fire first.
I assume that you've tried to start it. (edit: I see now that you have). How does it turn over?? With intermittent / odd cranking speed & sound, maybe even mechanical noise? IF so, probably out of valve timing (chain issues) and stop where you are at (for now).
IF it turns over normally...I'd suggest a shot of ether in the intake. IF it runs, you've got a "no fuel" issue. IF she doesn't run...no spark or flooded condition and we can go from there.
Nova resto pics
Old 03-20-2012, 12:18 PM   #5 (permalink)
Default There is a chance...
I've seen them in that scenario where the injectors leak by dumping excess fuel into the engine and a bear to restart after sitting, ESPECIALLY if the vehicle was put up before fully warmed, and the engine thinks it's in cold start mode while sitting there.
IF you feel that the engine turns over correctly / normally and a shot of ether doesn't immediately fire it up, consider it flooded. Gas to the floor, don't pump it and crank, crank. It will eventually start, shake, rattle and roll, clear out any mosquitoes and then settle out.
Nova resto pics
Old 03-20-2012, 12:26 PM   #6 (permalink)
It Honestly sounds like Timing chain Bad If you know what I mean...That Sound....It didnt even want to try to start?? No Odd noise when trying to start
Old 03-20-2012, 01:18 PM   #7 (permalink)
Then I'd suggest a leak-down style of compression test on each cylinder to see if the valves are in time and not bent.
90K is rather little for chain probs though, UNLESS the engine suffered from high mileage oil change intervals and / or very short repetitive trips.
It's either that and go "all in" and rip off the front timing cover and inspect.
Nova resto pics
Old 03-20-2012, 01:37 PM   #8 (permalink)
Okay Thanks For Info....I will get back to you shortly Thanks
Old 03-20-2012, 06:39 PM   #9 (permalink)
Hello again was wondering if I was to Tackle removing timing cover Will I be able to actually see a issue.....see a Problem etc. or Not????
Old 03-20-2012, 08:12 PM   #10 (permalink)
There would be two angles to take.
1. A visual inspection for apparent broken or damaged components.
2. A run through re-timing of the components to determine if everything is in spec.
But the timing won't change unless there is something catastrophically amiss, that should be obvious in the initial inspection.
Nova resto pics
