Go Back   Suzuki Forums: Suzuki Forum Site > Suzuki Models > Suzuki Vitara, Grand Vitara & XL-7 Forum (1999+) > 1G (2001-2006) XL-7
Suzuki-Forums.com is the premier Suzuki forum on the internet. Registered Users do not see the above ads.Please Register - It's Free!
Old 05-22-2009, 05:34 AM   #1 (permalink)
adal20 is on a distinguished road
Default How to replace cabin Filter
I have my xl7 for 3 years now , when I start my AC I can smell moisture when AC start running.Cabin filter never was replaced I now it is hiden in glowe department but air bag is just above .Do I need to disconect batery ?
adal20 is offline   Reply With Quote
Old 05-22-2009, 04:20 PM   #2 (permalink)
The text book answer is yes.
Click for pics
Old 05-23-2009, 11:08 AM   #3 (permalink)
No you don't really. You aren't going to be working everywhere close to the air bag to worry.
Pull the glove box out. (Open it, tilt down. Squeeze both sides of it inwards till it pops down. Pull the small dampener off the right side of the glove box so it can tilt down all the way.) Look straight in and you'll see a black cover. Unclip it at the bottom (one clip on each bottom side). Pull the cover off and slide the filter straight out. Take care not to dump anything into the heater box or you'll have to pull the blower motor out to clean any debris out of it.
Very easy job - 5mins your first time and 30 seconds after that!
Old 05-24-2009, 09:26 PM   #4 (permalink)
murcod's Avatar
I did mine yesterday. The filter isn't close to the airbag module and the only "electrical" thing I had to do was move a loom to one side in order to remove the filter.
So it's overkill unless you're really "ham fisted" !
David.
2004 XL-7 Limited.
murcod is online now   Reply With Quote
Old 05-24-2009, 09:29 PM   #5 (permalink)
XL7Limited's Avatar
no need to disconnect battery
