Tin-like rattling under car - Suzuki Forums: Suzuki Forum Site
Go Back   Suzuki Forums: Suzuki Forum Site > Suzuki Models > 1G (2001-2006) XL-7
Old 06-18-2017, 09:11 PM   #1 (permalink)
don_markos is on a distinguished road
Default Tin-like rattling under car
My 2004 XL7 has a horrible rattling underneath, loudest when cold started and eventually warms and disappears. When driving it sounds bad, like a thin tin pan or big washer nut rattling around a pipe at low RPMs (1800-2200K) at around 25-30 mph, then with acceleration it's gone. 2 separate mechanics checked the catalytic conv, exhaust, heat shields and all connections and nothing, they have given up. It's not coming from the engine like so many others. I believe the Zuks are infamous for noises but "holy mystery batman"? Help!!!!
don_markos is offline   Reply With Quote Quick reply to this message
Old 06-18-2017, 10:30 PM   #2 (permalink)
Baldan Dugly is on a distinguished road
These models are known for timing chain noise. Tensioners and guides die prematurely. I had to replace mine at 175k. The guides had disintegrated. Currently, I have a weak hydraulic in the head now that taps at start and the under load.
Sent from my Nexus 5 using Tapatalk
04 2.7L XL-7
06 2.0L Kia Spectra
Baldan Dugly is offline   Reply With Quote Quick reply to this message
Old 06-19-2017, 07:41 AM   #3 (permalink)
XL7Limited's Avatar
What you are hearing is the cat converter heat shield that has broken its weld and has fell onto the converter and rattling. Very common. Either reweld or remove it
Old 06-19-2017, 07:30 PM   #4 (permalink)
Yes I read much about that issue, noise doesn't seem to be coming from that area.
Old 06-19-2017, 07:31 PM   #5 (permalink)
Thats what seems like the area of the noise, I will check the cat heat shield again now...
Old 06-19-2017, 07:37 PM   #6 (permalink)
Banging the heck out it everywhere on the cat and around. No noise from there.
Old 06-20-2017, 09:00 AM   #7 (permalink)
mdc689 is on a distinguished road
i have seen those little brackets that bolt from the transmission to the exhaust manifold to break or crack even seen them missing. this will cause a bad rattle.
mdc689 is offline   Reply With Quote Quick reply to this message
Old 06-20-2017, 12:22 PM   #8 (permalink)
XL7Limited's Avatar
Banging it with your hand may not cause a rattle. Get it up on a lift and inspect the shields
Old 06-21-2017, 03:58 PM   #9 (permalink)
MDC i think thats it, there is a nut missing up under the bracket. Will report ASAP...
LX7 Limited- would never use my hands, both I and Mech have worked out the cat and shields to no avail. ty
