camshaft position sensor XL7 2003 v6 2.7 - Suzuki Forums: Suzuki Forum Site
Go Back   Suzuki Forums: Suzuki Forum Site > Suzuki Models > 1G (2001-2006) XL-7
Old 03-20-2017, 12:41 PM   #1 (permalink)
my2003xl7 is on a distinguished road
Default camshaft position sensor XL7 2003 v6 2.7
What are the step to remove and install a new CPS on a 2003 xl7 v6
my2003xl7 is offline   Reply With Quote Quick reply to this message
Old 03-20-2017, 01:23 PM   #2 (permalink)
Unbolt, remove, replace, adjust ignition timing - this last requires a Suzuki scan tool and a timing light.
Old 03-20-2017, 01:35 PM   #3 (permalink)
The details of which can all be found here.
http://www.suzuki-forums.com/2g-1999...arts-tech.html
Welcome aboard!
'03 Honda Odyssey
Old 03-21-2017, 07:30 AM   #4 (permalink)
Thank you for the info.I did removed it yesterday. I have to remove the transmission dipstick part to be able to remove the sensor. Have to go under the car to remove the two bolt holding the dipstick. While under the car I saw lots of oil. It must need a new cover gasket replacement. Waiting for the part to arrive from rockauto.
Old 03-21-2017, 08:23 AM   #5 (permalink)
There are many potential oil leak sources to contend with.
Clean and insect closely. Even the old CPS to engine seal is a possible leak source back there.
'03 Honda Odyssey
Old 03-24-2017, 10:02 AM   #6 (permalink)
Default got the new part
Got the new part and tried to installed it but after 45 mins of trying to put it in and try to aligned it, I gave up. what am I doing wrong? the old part fit in so easy but the new part from beck/arnley part number 180-0289 just don't want to go in. I also used a mirror to see the angle and I did the right angle but still no luck.
Old 03-24-2017, 11:27 AM   #7 (permalink)
That appears to be the correct part number...
2003 SUZUKI XL-7 2.7L V6 Camshaft Position Sensor | RockAuto
Pay close attention to how the ears of the coupler are clocked. I think that they are off-set to allow only one position match-up. You may be 180 degrees out.
'03 Honda Odyssey
Old 03-26-2017, 02:38 PM   #8 (permalink)
Baldan Dugly is on a distinguished road
You are correct. It goes one way only. A new seal makes it difficult, but it's necessary. That's where my major oil leak was. I had to remove the cover screws to line it up. Putting the screws back in is a pain.
04 2.7L XL-7
06 2.0L Kia Spectra
Baldan Dugly is offline   Reply With Quote Quick reply to this message
Old 03-26-2017, 05:59 PM   #9 (permalink)
Glad that you got it sorted!
'03 Honda Odyssey
