Rev limiter ex - Suzuki Forums: Suzuki Forum Site
Go Back   Suzuki Forums: Suzuki Forum Site > Suzuki Models > 1G (2001-2006) XL-7
Old 02-16-2017, 04:27 AM   #1 (permalink)
Baldan Dugly is on a distinguished road
Default Rev limiter
Do 2004 xl-7's have rev limiters? I was on a trip and my cruise control down shifted and really went to far in my opinion. Now I have a valve tapping noise. It down shifted and stuck there and my cel started flashing. I shut the cruise off asap but now I'm worried. Drives fine, just taps now.
04 2.7L XL-7
06 2.0L Kia Spectra
Baldan Dugly is offline   Reply With Quote Quick reply to this message
Old 02-16-2017, 03:58 PM   #2 (permalink)
aquanaut20's Avatar
Flashing MIL = miss fire.. Cruise will disengage..
Do you still have a CEL?
Can you do a drop test to check which pot is not firing?
... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 02-17-2017, 02:52 AM   #3 (permalink)
... Philip
I checked and had two pending codes. One was multiple misfire. The other was cylinder 5 misfire. It runs fine now, it is tapping like a valve out of adjustment. I wonder if I lightly hit a valve with a piston.
04 2.7L XL-7
06 2.0L Kia Spectra
Old 02-17-2017, 09:18 AM   #4 (permalink)
XL7Limited's Avatar
no rev limiter on it.
XL7Limited is online now   Reply With Quote Quick reply to this message
Old 02-20-2017, 10:33 PM   #5 (permalink)
primordial soup's Avatar
primordial soup is on a distinguished road
LOL
What? Do you mean you can rev the h27 to 7k+ rpm? I know of no modern electronically controlled engine that does not limit RPM.
OP, when you say it went too high, like close to redline or did you confirm it was way past 6500 rpm?
2006 XL-7
5-AT 4x4 2.7L
primordial soup is offline   Reply With Quote Quick reply to this message
Old 02-21-2017, 06:49 AM   #6 (permalink)
XL7Limited's Avatar
ive never hit it on mine and I had it up over redline.
Old 02-22-2017, 04:13 AM   #7 (permalink)
Originally Posted by primordial soup View Post
LOL
I did not confirm. It just revved higher than I have ever heard and the cel started flashing. The tap is now intermittent and not constant. My Dad thinks maybe a hydraulic is malfunctioning if these xl7's have them or do they have solid lift cams?
04 2.7L XL-7
06 2.0L Kia Spectra
Old 02-22-2017, 04:15 AM   #8 (permalink)
That's reassuring.
04 2.7L XL-7
06 2.0L Kia Spectra
Old 02-22-2017, 06:41 AM   #9 (permalink)
XL7Limited's Avatar
The 2.7 has hydraulic lifters. If the cel light is on, id say you have a larger issue then a bad lifter.
Old 02-22-2017, 12:50 PM   #10 (permalink)
Hmm I go full throttle often and it always shifts right around 6300rpm
