starter removal - Suzuki Forums: Suzuki Forum Site
Go Back   Suzuki Forums: Suzuki Forum Site > Suzuki Models > 1G (2001-2006) XL-7
Old 11-24-2007, 12:26 PM   #1 (permalink)
fartfignewtons is on a distinguished road
Default starter removal
Anyone have tips on the best way to remove a starter from a 4x4 model? Things are super tight in there and I not sure if I need to raise the engine or remove the front differental? Not sure if it can go in without the two things mentioned above?
I think the grease in the starter is keeping it from fully throwing itself forward and engaging the engine flywheel. Ever heard of such a thing? This only happens when it is cold out side. Thinking the shaft is bent as well?
The starter is getting plenty of juice from the battery! Check with a volt/amp meter.
T
'01 XL7 Touring Plus 4X4
fartfignewtons is offline   Reply With Quote Quick reply to this message
Old 12-04-2007, 10:33 PM   #2 (permalink)
Any tech's out there that can post an exploded view of the starter on an '01 XL-7?
Also, not sure why the factory used an over sized torx bolt to hold down the generater, I'm not having any luck removing it. Can not find a nut on the other end; is this bolt left hand thread?
If I get it out, I will pitch it in the trash and get a standard bolt head. Dumb A$$ design.
Any help with the starter issue would be much appreciated!
T
Old 12-05-2007, 01:45 AM   #3 (permalink)
murcod's Avatar
Have you got the manuals at this link? http://www.suzukiinfo.com/vitara/sq416.zip
If you follow the instructions for the SQ625 it should be the same as your XL-7.
Old 12-06-2007, 02:37 AM   #4 (permalink)
tds7 is on a distinguished road
fartfignewtons,
Hope we can find out how to get that alternator pivot bolt loose, when I changed my belt I couldn't get it broke loose. I'll agree what a goofy idea and place to put a torque head bolt. I sprayed penetrating oil on it and was finally able to swivel alternator to replace belt.
tds7 is offline   Reply With Quote Quick reply to this message
Old 12-06-2007, 08:54 PM   #5 (permalink)
Originally Posted by tds7 View Post
fartfignewtons,
I had to use a long screw driver to force back the alternator when I replaced the belts just over a year ago. No luck in removing the factory retarded T45 torx bolt installed under the alternator. WTF!
GF '01 Tracker has a standard bolt!
I see you were not able to remove it as well!
T
Old 12-12-2007, 01:34 AM   #6 (permalink)
Well, since there was no response in help removing a starter, I went ahead and removed it along with the alternater.
I was dreading having to mess with that torx bolt from the factory.
I mean, who in the hell use's an M10 x 1.25 x 85mm bolt to pivot an alternater??? GD engineers!!!
Below are some pic's of the ordeal...
Can you tell that I'm a bike mechanic?
T
Old 12-12-2007, 01:36 AM   #7 (permalink)
Sorry, didn't mean to hit submit until these last few photo's...
alter all cleaned up
starter
Once placed back in the truck, she starts up ever time!!!
T
Old 06-08-2010, 04:31 PM   #8 (permalink)
Scorch's Avatar
Gallery: 4
Scorch is on a distinguished road
GD engineers!!!
Amen, brother! I just found out the hard way this is not a 5 or 6mm allenhead. What type torx fits it? I tried a 45 and 47, neither seemed to fit.
Scorch - Suzuki: 2010 Grand Vitara Limited, '08 V-Strom 650, '75 GT380, '03 XL-7 (RIP)
Scorch is offline   Reply With Quote Quick reply to this message
Old 06-08-2010, 05:11 PM   #9 (permalink)
02XL7ZUK is on a distinguished road
So what did you have to remove to get the starter out? Mine might need replacing soon as wel. It looked like I would have to remove and engine mount? If I remove the alternator I can take the starter out where the alternator used to be? Those bolts are T-50 torx bolts. BTW can anyone tell me where the hell the knock sensor is located on the 2.7?
02XL7ZUK is offline   Reply With Quote Quick reply to this message
Old 06-09-2010, 01:23 AM   #10 (permalink)
Scorch's Avatar
Gallery: 4
Hmm... I tried 45 and 47, wasn't sure the 50 was fitting. Ended up cutting the head off with a Dremel tool.
Sorry, I have no idea where the knock sensor is, wish I had a repair manual.
