Factory manual says to remove Rack and Pinion Steering on way to removing timing chain cover and further to remove the cylinder head. Please share your experiences with a cylinder head R&R on the Suzuki 2.0 liter. My 1999 Tracker is a 2 wheel drive. Thanks
Tucson Arizona USA
1991 Tracker 4x4 2 door conv Auto
1994 Tracker Tin Top 4x4 stick 16valve
1996 x90 2wd stick
1997 Sidekick 4x4 4 door Auto
1990 Samurai stock EFI
Have 1999 Chevy Tracker with 2.0 liter J20. Trying to feel my way into self repair of timing chain replace and perhaps cylinder head rebuild. I guess my hope was to get as many experienced replies as possible. Timing chain and head R&R questions might get a different (better) response.
Tucson Arizona USA
1996 x90 2wd stick
Motor runs well- compression shows well within specs and all cylinders equal. But get bubbles in radiator neck and then overheating (about 5-10 minutes after starting) Am considering Therma Gasket head gasket fix (money back guarantee!). Started reading FSM and it started taking about removing oil pan and rack and pinion steering-- the Therma Gasket pour fix started looking real attractive. Did more reading on this forum (timing chain sticky) no mention of all this oil pan rack removal SO trying to get hands on answers to realistic removal tips. Thanks for your hands on tips for timing chain cover removal and cylinder head R&R
Tucson Arizona USA
1996 x90 2wd stick
So- Please tell of your hands on experiences with removal of cylinder head J20 1999 Tracker USA 2.0 liter. Factory service manual says to remove oil pan also rack and pinion steering?? Why?? Tell me what you've seen and learned Thanks so much
Tucson Arizona USA
1996 x90 2wd stick
