Low oil pressure @ idle...? - Suzuki Forums: Suzuki Forum Site
Old 12-08-2012, 10:12 PM   #1 (permalink)
HeatherandJohns2001 is on a distinguished road
Question Low oil pressure @ idle...?
2001 Chevy Tracker....
2.0L Automatic
I replaced timing chains after guide came apart and damaged components....
Now engine low oil pressure light is coming on at idle, is there any hope?
John
HeatherandJohns2001 is offline   Reply With Quote
Old 12-09-2012, 03:03 AM   #2 (permalink)
aquanaut20's Avatar
Did you reuse the metal gasket on the tension-er? .... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 385k
99 Tracker, 4dr, 4x4, 2L DOHC, auto 189k
Old 12-09-2012, 08:21 AM   #3 (permalink)
And I'd verify the actual pressure with an independent gauge too. You may simply have a faulty sender or wiring connection issue.
'99 Grand Vitara JLX, 2.5L V-6, 4WD, 5 spd std, '00 "Limited" leather interior, OE alarm & SAT radio.
'53 Chevy 3100 Pick-up w/327, TH400 trans w/78' Nova rear end.
'72 Chevy Nova. One owner, SB, A/C, power disc/drum & steering.
Nova resto pics
... http://s155.photobucket.com/albums/s...o/1972%20Nova/
Old 12-09-2012, 12:32 PM   #4 (permalink)
Yes, I did reuse the metal gasket....
I'll check actual pressure....
Old 12-09-2012, 09:26 PM   #5 (permalink)
Why do you ask?
Old 12-09-2012, 10:12 PM   #6 (permalink)
aquanaut20's Avatar
Originally Posted by HeatherandJohns2001 View Post
Why do you ask?
Because it is designed as a one time use part, having said that if it shows no damage and is a good fit!!.
I have reused with CAUTION (leaks oil/pressure)...
Confirm your pressure with gauge..... Philip
Old 12-10-2012, 10:40 PM   #7 (permalink)
So you're saying that you've reused them, but they did leak? Or they may leak?
Mine was okay... Not really sure how they could get damaged...
How about the oil pressure relief valve in the top of head... Have those been known to stick open or cause any troubles...?
John
Old 12-10-2012, 10:47 PM   #8 (permalink)
Originally, the oil pressure switch was leaking, I imagine this leak is what caused my timing chain problems to begin with, I purchased the car, cheap, with the timing chain issue... I replaced all timing chain components and then I found the oil leak....
Anyhow, after replacing timing parts, and changing oil.... I test drove vehicle, all was fine until it was up to operating temperature... Then, at idle, light started flickering.... Then, I found leak at switch and replaced switch... So, flickering has occurred with two switches..
I still need to see what my actual pressure is...
