Alternator continues to fail after new installs - Page 2 - Suzuki Forums: Suzuki Forum Site
Old 12-11-2012, 12:16 PM   #11 (permalink)
Have you been running DC/AC inverters, a winch, huge music amps or had repeated jump starts?
'99 Grand Vitara JLX, 2.5L V-6, 4WD, 5 spd std, '00 "Limited" leather interior, OE alarm & SAT radio.
'53 Chevy 3100 Pick-up w/327, TH400 trans w/78' Nova rear end.
'72 Chevy Nova. One owner, SB, A/C, power disc/drum & steering.
Nova resto pics
... http://s155.photobucket.com/albums/s...o/1972%20Nova/
Old 12-11-2012, 12:26 PM   #12 (permalink)
aquanaut20's Avatar
Anyone who diagnosed a burned diode without first dis-assembling the alternator has his head up his ass.
Each diode MUST be disconnected to test. Philip
92 Ford Explorer, 450k
97 Ford Explorer, 385k
99 Tracker, 4dr, 4x4, 2L DOHC, auto 189k
Old 12-11-2012, 06:31 PM   #13 (permalink)
rmjindls12 is on a distinguished road
none of the above.
wow, harsh. I don't think I said anyone diagnosed a burned diode. I did mention that AZ put the car on their tester and it showed a bad diode. Now they may be the same, but I'm not a mechanic and I thought the tester AZ uses was supposed to be accurate. But I do understand what you are saying, never the less.
rmjindls12 is offline   Reply With Quote
Old 12-11-2012, 06:54 PM   #14 (permalink)
aquanaut20's Avatar
Automotive alternators are generally 3 phase A/C, using diodes to clip the A/C to 1/2 wave. This requires 6 diodes 3 each of + collector and 3 of negative. Each of these banks are assembled in parallel and in series with the stator coils. So if one diode goes open it is not discovered unless dismantled, if on the other hand a diode shorts the whole bank will show the short.... again to test it must be dismantled.... Philip
Old 12-12-2012, 02:25 PM   #15 (permalink)
The jpg was very helpful. I will hold onto it as well as all the replies and find an auto electrician. Hopefully I can get this thing resolved and I don't have to look for a different auto.
Old 12-12-2012, 06:30 PM   #16 (permalink)
Phil - have you ever scoped the alternator output? In theory at least, an open diode should result in increased ripple on the output, I'd like to think it would be visible if scoped with a suitable load.
Having said that - I have no idea what the AutoZone tester is capable of.
93 - 1.3 Suzuki Swift GLX
98 - 2.0 Suzuki Grand Vitara
fordem is online now   Reply With Quote
Old 12-12-2012, 07:54 PM   #17 (permalink)
aquanaut20's Avatar
I have a MIL spec scope ($10,000) that does detect the ripple, but I also have a retail spec scope that does not. My guess is that the autostore would not have a MIL scope and the employees would not be trained in its use......
I have seen some of the equipment they use, a computerized Volt meter(2x5amp clams, direct to power source) that used a logics table to calculate load..Yes light/good, no light/bad.....Philip
Old 03-19-2013, 05:40 PM   #18 (permalink)
drowan is on a distinguished road
Did you find an answer jm? I am in the midst of removing my fourth alternator in 8-9 months. 2001 GV 2.5. 1st was rebuilt by a local independent, second was reconditioned from AZ, 3rd was it's warranty replacement.
drowan is offline   Reply With Quote
