02 grand vitara mass air flow sensor? - Suzuki Forums: Suzuki Forum Site
Old 12-01-2012, 11:11 AM   #1 (permalink)
robertlaquay is on a distinguished road
Default 02 grand vitara mass air flow sensor?
have an 02 suzuki grand vitara 2.5.have a ck engine light come on had autozone pull a code yesterday said mass air flow sensor.was hoping to just buy some airflow cleaner and of course this doesnt have the normal type mass air flow sensor as most cars.seems like this one is an actual sensor,if anyone can help where exactly this is im pretty sure its right on the throttle body,am i able to clean it or anything is the actual sensor just done cuz its kinda expensive like $160 and 60 core.the light goes out every now and then and cuts off every now and then,if any1 has a link to a better pricedo ne online that may help as well thanks
robertlaquay is offline   Reply With Quote
Old 12-01-2012, 11:30 AM   #2 (permalink)
You should try cleaning it.
Also see...
http://www.suzuki-forums.com/1g-1999...ensor-maf.html
'99 Grand Vitara JLX, 2.5L V-6, 4WD, 5 spd std, '00 "Limited" leather interior, OE alarm & SAT radio.
'53 Chevy 3100 Pick-up w/327, TH400 trans w/78' Nova rear end.
'72 Chevy Nova. One owner, SB, A/C, power disc/drum & steering.
Nova resto pics
... http://s155.photobucket.com/albums/s...o/1972%20Nova/
Old 12-01-2012, 11:49 AM   #3 (permalink)
yea i blew out the connector and the connecter side of the sensor should u pull it off and ck out the inside area and clean that?i bought some of the mass air flow clearner expecting to have a normal type one not sure if i still need to use that or just with a rag.thanks
Old 12-01-2012, 12:42 PM   #4 (permalink)
The MAF cleaner is essentially an aerosol that is used to "wash" any contaminants off of the sensor (not the connector) - I would suggest you not touch the sensor itself.
93 - 1.3 Suzuki Swift GLX
98 - 2.0 Suzuki Grand Vitara
Old 12-01-2012, 12:48 PM   #5 (permalink)
soo take the 2 screws off and clean the inside part with the cleaner?and is there a good tool any1 knows off to getot the bottom screw,i only have basic tools with me kind of a pain to get to that 1 thanks
Old 12-03-2012, 03:14 PM   #6 (permalink)
on this 2.5 the airbox duct that goes up under the strut bar,when u pop that off the engine side is that the mass air flow sensor?or is there just a sensor.problem is the duct wont come out enough under the strut bar to do anything if that is the maf to clean.thanks
Old 12-03-2012, 03:45 PM   #7 (permalink)
The MAF is buried, attached to the throttle body.
See vol 2 of 2 in the Service manual, H25 section here...
http://www.mediafire.com/view/?oddx0uesumi4ggs
Nova resto pics
Old 12-03-2012, 04:29 PM   #8 (permalink)
so anotherwards if its pulling a code i should try the sensor 1st with the 2 screws
Old 12-06-2012, 04:54 PM   #9 (permalink)
replaced the sensor w 2 screws and to no avail same problem,bogging down basically maybe even worse,light is still on any ideas?
Old 12-07-2012, 05:27 AM   #10 (permalink)
Have it re-scanned and give us the code (codes?).
It may be time to regroup here.
Nova resto pics
