Radiator cooling fan - Suzuki Forums: Suzuki Forum Site
Old 11-25-2012, 01:05 PM   #1 (permalink)
billsmartis is on a distinguished road
Default Radiator cooling fan
Anybody know where I can get an electric radiator cooling fan to fit a 2000 2.0 tracker? This is not the condenser fan but the main cooling fan.
1992 Kick JX 4x4 4door 1.6-16 valve Fed 235/15s Home made Rear 2" lift 5 Speed
2000 Tracker 4x4 4 door 2.0 4 speed automatic stock
2011 SX4 Hatchback AWD 2.0 CVT stock
billsmartis is offline   Reply With Quote
Old 11-25-2012, 02:47 PM   #2 (permalink)
Bill, I believe you'll have to "re-engineer" that yourself - the 2.0 engines GVs upto 2005shipped with a viscous coupled fan.
I've considered it, but never done anything more than push ideas around - primary reason being that my stock fan works fine, second reason is that I've never been able to find out what the CFM of the stock fan is, and the third reason is that good quality fans & controllers don't come cheap.
You have a bunch of different options - a single large 16" fan mounted to use the existing shroud and either run that full speed (relay switched) or variable speed (through a controller), or, two smaller fans side by side in a custom built shroud and then you can run those in series (low speed for low temp) or parallel (full speed for higher temp) - this last method is how Suzuki did it on the 2006+ GVs with the 2.0 engine - the fans are switched by the ECU, so whilst it may be possible to adapt the fans, you'll need to devise your own controls.
One thing I did find is that two smaller fans are capable of moving significantly more air than a single large one
93 - 1.3 Suzuki Swift GLX
98 - 2.0 Suzuki Grand Vitara
Old 11-25-2012, 03:21 PM   #3 (permalink)
Thanks fordem I think I'm going to mount a 16 inch fan in the existing shroud and get one of the stick through the radiator thermostats and hope for the best.
Derale 16738 Fan Control Thermostatic 180 Degrees On/170 Degrees Off Kit | eBay
UNIVERSAL SLIM 16" PULL/PUSH RADIATOR ENGINE BAY COOLING FAN+MOUNTING KIT BLACK | eBay
Old 11-25-2012, 04:48 PM   #4 (permalink)
murcod's Avatar
I'd highly recommend looking at the Spal range of fans. I've done a conversion on my 2004 XL-7 using their twin 11" fan assembly and it works better than the viscous fan. There's a long thread on it with pics on here somewhere (in the XL-7 section?) searching should bring it up.
Whatever you do, don't skimp on the fan or wiring
David.
2004 XL-7 Limited + 2011 Kizashi Touring.
Old 11-25-2012, 04:52 PM   #5 (permalink)
murcod's Avatar
http://www.suzuki-forums.com/suzuki-...highlight=spal
David.
Old 11-25-2012, 08:21 PM   #6 (permalink)
Originally Posted by murcod View Post
Waaay to rich for a vehicle that has 207,000 miles on it. I already ordered a 16" fan and a thermostat kit that I mentioned above and will mount it on the original fan shroud. I don't like the idea of mounting a fan to a radiator with the plastic hardware putting a load on the radiator tubes considering there plastic too.
Old 11-25-2012, 08:30 PM   #7 (permalink)
Don't forget to post pictures when you do it - might help me decide how to do mine - if I ever get a round toit.
Old 11-26-2012, 06:31 PM   #8 (permalink)
murcod's Avatar
Are you sure there's enough clearance for the 16" fan between the water pump/ drive belts and radiator? I think that was one of the reasons I went with the dual 11" - plus they covered more of the radiator and flowed more air.
David.
Old 11-26-2012, 06:52 PM   #9 (permalink)
The shroud is 20" in diameter and the water pump is mounted on the left side of the engine. The fan is mounted on a removable bracket so there's nothing between the engine and the radiator once the fan bearing and bracket are removed. There will be more than enough room to mount the electric fan to the existing shroud.
Old 11-26-2012, 07:34 PM   #10 (permalink)
Bill has the 2.0 I4 engine (as do I) so probably more space than your XL-7 had - I believe your fan bolts direct to the water pump, whilst ours has it's own mount that can be removed.
