wiper motor - Suzuki Forums: Suzuki Forum Site
Old 11-19-2012, 05:36 AM   #1 (permalink)
stuart cormie is on a distinguished road
Default wiper motor
Hi Can you tell me how to change a front wiper motor on a 1998 vitara jx4u.
Im sure it will be straightforward but wanted to check here first.
Many thanks
stuart
stuart cormie is offline   Reply With Quote
Old 11-19-2012, 10:12 AM   #2 (permalink)
aquanaut20's Avatar
What issue do you have with the motor?? Philip
92 Ford Explorer, 450k
97 Ford Explorer, 390k
99 Tracker, 4dr, 4x4, 2L DOHC, auto 192k
Old 11-19-2012, 11:15 AM   #3 (permalink)
started to go very slow. then intermitant stoped and then speed one stopped but full speed works.
Thanks for your help
Old 11-19-2012, 11:34 AM   #4 (permalink)
aquanaut20's Avatar
I would be more inclined to check the switch before condemning the motor... Philip
Old 11-19-2012, 11:44 AM   #5 (permalink)
Hi Philip i will have to take it to an auto electrician to do that as i dont know how to check it
Old 11-19-2012, 07:44 PM   #6 (permalink)
Let's start with where are you, and then follow that with what vehicle are you driving? 98 was a changeover year for Suzuki and your 98 Vitara could be either an SE series or an SQ series.
On the SQ series the wiper motor is located directly behind the battery - there is a 4 pin connector between the motor that is susceptible to corrosion damage from battery acid, and will cause the symptoms you describe.
93 - 1.3 Suzuki Swift GLX
98 - 2.0 Suzuki Grand Vitara
fordem is online now   Reply With Quote
