I wonder what a needle coil pack is?
Don't you find it strange that the needle coil pack (whatever it is) wasn't causing a judder before the clutch was changed? Or that this needle coil pack only breaks down when you're pulling away?
I'm guessing here - but - if they're calling the ignition coils needle coil packs, then, they're BSing you, an ignition coil breaking down won't cause a judder only at move off - on the other hand, a defective clutch will, and it's possible that they did not machine the surface of the flywheel when they did the clutch job - it's not always necessary, but it's usually a good idea.
93 - 1.3 Suzuki Swift GLX
98 - 2.0 Suzuki Grand Vitara
