Water pump question? - Suzuki Forums: Suzuki Forum Site
Old 09-14-2011, 10:20 PM   #1 (permalink)
Tracker02 is on a distinguished road
Default Water pump question?
Hey everyone. I need to call on your expertise again to make sure I'm not getting hung out to dry by my mechanic.
I have a 2002 Chevy Tracker ZR2, which as most of you know, is essentially the same as a 2002 Suzuki Grand Vitara. It's a 2.5L V6 with an automatic transmission. If you need any more info, let me know. I posted not that long ago when I first bought the vehicle and since then I've had mixed results with it. The previous owner clearly didn't believe in the same level as maintenance as I do. Lots of small things, nothing major. Until now, at least...
Basically, the problem is that I took my truck to my usual mechanic (been my mechanic for years) and asked him to check if there were any leaks and to look into a noise I have going on in the back. He said he found that the water pump was leaking antifreeze. I already know he's unfamiliar with the truck and, to be honest, I think he may be unfamiliar with trucks in general. I mostly only see cars when I'm there and I've only ever owned cars up to now. He tells me that the labor to replace the water pump is going to be 11+ hours and that the water pump itself is $200+. He did admit that typically the job is 3, maybe 4 hours and the average water pump is only $100 or so. He says that the water pump is located in a really awful place and he's going to have to do a lot to get it out.
Does this all check out? Why is the labor for this particular vehicle so high? If anyone can give me any information, advice, or help, I would really appreciate it. I'm enjoying my Suzuki Tracker, but this all sounds a little crazy to me.
Tracker02 is offline   Reply With Quote Quick reply to this message
Old 09-15-2011, 03:07 PM   #2 (permalink)
BumpLover is on a distinguished road
Garage
I would get a new mechanic ASAP.
You did NOT specificy what motor you have, that might change the pump who knows... look for your motor model and match it up...
He's asking you for money and an arm..
Labor is never going to be that much... Is he going to rebuild your motor or something????
2002 CHEVROLET TRACKER Water Pump
Check what engine you have and match...
I haven't done it but I think changing a pump is not that hard... never EVER 11 hours...
Let's wait and see for Max and Phillip but I think you should kick this guys arse!
Vitara 2003, 2WD
2.0 L 2000cc L4 FI DOHC motor -J20A-
Full auto 3 speed transmission + O/D
105k miles
To do list:
Paint calipers and drums.
Paint all outside plastic (centercaps, trims, roof and maybe fenders)
BumpLover is offline   Reply With Quote Quick reply to this message
Old 09-15-2011, 03:22 PM   #3 (permalink)
lumpylarry's Avatar
You did mention 2.5l engine..
These waterpumps do take a little more time compared to most other vehicles as they are located in behind the timing cover
It's true that the book time for job lists at somewhere around 8.5 hrs.
But that time includes removing front diff, oil pan, intake, valve covers etc..
If you shop around you can find someone with a little experience on these engines that
will be willing to do it for around 5..
2008 suzuki SX4 sport sedan 5spd FWD
2007 suzuki boulevard C50 SE
2001 suzuki swift 1.3 5spd blue
Old 09-15-2011, 03:28 PM   #4 (permalink)
lumpylarry's Avatar
I even bet your local Suzuki dealer will give you a better quote than that..
Also, if I were doing the job, I'd throw in a #1 chain tensioner just for fun..
Old 09-15-2011, 04:48 PM   #5 (permalink)
Garage
OMG LOL xD I had a deadline to hand in something and didn't read it all that well... xD
So, my bad for that.
Vitara 2003, 2WD
105k miles
To do list:
Old 09-15-2011, 08:54 PM   #6 (permalink)
The water pump is pictured in the center (with the 4 bolts on it's flange) as shown here with the front timing cover removed.
It's rather buried and significant interference needs to be removed to access the WP.
Larry...does one really need to drop the oil pan (and diff if so equipped) to gain access? I thought not.
Water pumps...$31 bucks and up.
Old 09-15-2011, 09:35 PM   #7 (permalink)
lumpylarry's Avatar
No. Not necessary. I don't even take off the intake or valve covers.
But the book tells you to because of the tight fit against the timing cover..
In reality it can be done in under 2 hrs but I don't know anyone that's will do it for less than 5
Old 09-15-2011, 11:09 PM   #8 (permalink)
Thank you, guys. I appreciate the help. It sounds to me like this is basically because my mechanic is so unfamiliar with my Tracker that he has no idea what he's doing. You would all recommend getting a second opinion? Maybe even taking it to a Suzuki dealer?
Again, thank you. I can't tell you how much help just reading you guys discussing this has been.
Old 09-16-2011, 12:32 AM   #9 (permalink)
Garage
Yeah, get a second opinion of someone who is used to dealing with these.
If you are lucky you might get to a dealer and instead of paying the company for the job you could get a Suzuki mechanic to do that for you for less... All I can say is this, read read and read!!!! You need to make sure the mechanic knows what you are talking about so he doesnt jack up the price, you just need to make it look like you can DO it but don't want to. Keep looking there are decent and honest to god mechanics you just need to dig deeper for them, and glad we have all been of help, it's a pleasure for all of us!
Vitara 2003, 2WD
105k miles
To do list:
Old 09-16-2011, 12:27 PM   #10 (permalink)
aquanaut20's Avatar
Last one I did 3.5hrs, using air tools and the assistance of 2 Gdaughters (18 & 19), incl an old timers nap while the girls finished the unbuttoning..... Philip
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Security Question
