How to tie wrap/ lock the front differential acuator? - Suzuki Forums: Suzuki Forum Site
Old 01-16-2010, 06:20 AM   #1 (permalink)
abarnes's Avatar
abarnes is on a distinguished road
Default How to tie wrap/ lock the front differential acuator?
I have searched and cannot find details on how to lock the front diff acuator. Please help.
2001 Grand Vitara V-6
abarnes is offline   Reply With Quote Quick reply to this message
Old 01-16-2010, 09:03 AM   #2 (permalink)
Right now there isn't that much detail - Zukiworld might have a little more than here, so try a search over there - the guy who did it uses the same handle (Rally_T-115) both here & there - you could also try sending him a PM.
When he originally did the mod he did not take pictures, but, he crushed one of the tye-wraps and has since done it over, so hopefully he took pictures this time.
Essentially you need to get the "third member" or diff carrier out of the axle and then slide the clutch over and slip the tye-wraps in between it and the actuator itself.
Don't forget to install free-wheeling hubs if you go this route.
Old 01-16-2010, 09:45 AM   #3 (permalink)
Check this thread. The tie wrap fellow is referenced in it...
http://www.suzuki-forums.com/1g-1999...ngaging-2.html
Old 01-16-2010, 04:07 PM   #4 (permalink)
abarnes's Avatar
Default Thanks
This link has clear pictures and instructions
Damn I think I really broke something now...
Old 01-16-2010, 04:29 PM   #5 (permalink)
I know.
That's why I linked it for you.
Old 02-02-2010, 04:29 PM   #6 (permalink)
abarnes's Avatar
Default Look what I found
When I took the front diff apart, I found a previous repair. Someone had welded the actuator. The welds broke, That is why when I first bought the GV the 4wd worked. Then it stopped working. I wonder why the welds broke, how much pressure is there? How could tie wraps hold it?
How to tie wrap/ lock the front differential acuator?-pic_0031bbbb.gif
Old 02-02-2010, 05:31 PM   #7 (permalink)
They apparently WON'T (always). That's why the tie wrap guy had to go back and re-do his after a hard launch.
Security Question
