Originally Posted by mr.cruiser
HI! Since this summer , we have a 2002 vitara soft top with 145 000 km on the 2.0L gas engine. I read that there are some problems with the timing chain with theses engines. For now, I have no problems but i'd like to know at how many km I should change it? Also I have seen a few vitara with broken rear axles. Is this a common problem?
Thanks!!
To the best of my knowledge the 2.0 four cylinder engines do not have a history of timing chain problems, it's the early V6 engines that do. The chains are not like belts wit a projected life span of xx,000 miles, so I would say listen to the engine on a cold start, and as long as it's not excessively noisy (I'm not talking about the fan noise here, but a metallic clatter or rattle) then don't get too excited - make sure to change the oil & filter regularly and you should be fine.
Rear axles - this is the first I'm hearing about it - front axles are known to give trouble, and will break on a raised vehicle with over sized wheels, if you're into rock crawling and the like - but other than that I'm not aware of any issues there either.
