Burning smell and smoke from under hood - Suzuki Forums: Suzuki Forum Site
Old 10-25-2009, 02:18 PM   #1 (permalink)
Gallery: 4
a-whiteway is on a distinguished road
Exclamation Burning smell and smoke from under hood
A few days ago i had my dealer put a new water pump in my 04 GV (second pump in 4 months). While they had it apart they put in a new timing chain tensioner because some models have a history of them going weak. When i got it back from the dealer i smelled a burning smell and thought it's likely just some chemicals and fluids that got on some parts during the repairs burning off or my brakes. The other night i was backing into a parking spot and when i went from R to P the engine died and the dash lit up like a christmas tree. I turned it on again with no problem but when i went through all the gears while parked the engine sputtered when i went from P-R-N-D and at one point the check oil light almost came on. I took it for another drive today and the service engine soon light came on. I had a look under the hood and there was light smoke coming from the drivers side and i could see kind of fluid under the oil filter. Does anyone have an idea whats going on. It could be something as simple as the oil filter isn't on tight enough or something much more serious.
a-whiteway is offline   Reply With Quote Quick reply to this message
Old 10-25-2009, 02:41 PM   #2 (permalink)
aquanaut20's Avatar
Smoke and smell never good, if you suspect the filter leaking, let cool and try tightening by hand, if that does not fix leak, remove filter(check for double gasket), clean seating surface, oil gasket and reset or replace filter.
If the CEL is illuminated, scan for codes and let us know...
If it related to work performed by dealer let them rectify the problem to maintain any warranty fallback.
92 Ford Explorer, 450k
97 Ford Explorer, 400k
Old 10-25-2009, 02:55 PM   #3 (permalink)
x_sgs_x is on a distinguished road
This is a pretty bad issue. I would call the dealership and have them fix it
x_sgs_x is offline   Reply With Quote Quick reply to this message
Old 10-25-2009, 11:06 PM   #4 (permalink)
tmcalavy's Avatar
tmcalavy
Ditto...call the dealer, the tow and fix should be their baby.
Say Hello to my leetle friend!
tmcalavy is offline   Reply With Quote Quick reply to this message
Old 10-30-2009, 07:57 PM   #5 (permalink)
Gallery: 4
turned out to be that the gasket on the valve cover plate wasn't reset right
Old 10-31-2009, 08:24 AM   #6 (permalink)
That makes sense on the leak / smell / smoke issue but not the quitting and CEL light. Watch it close and return it at the slightest issue from here on out.
Security Question
