Originally Posted by unimogdave
Going from long ago memory so apologize if the facts are off....
I ran a Samurai for years with 31s. I had 3.91 dif and a SJ410 transfer case which I believe was 1.4 underdrive in high range so thats equiv to about 5:46. As it was also my daily driver I had a set of P235-15 for every day use and put on the 31.s for trail riding. I only had a 1.3 litre motor. I would suggest forgetting about overdrive at a minimum and see if that improves performance? You want to keep those 31s for the trail.
I dont think your far off on your figures.
I had a zuk with 5:12's, 4:1 t case and 35" tires for years.
This Tracker serves a completely different purpose. I drive it to work and wanted to be able to take it to the local hills once in a while.
First and foremost it needs to be drivable on the freeway, no compromises here at all..
The 31's are off, running a LT235 now. I don't like it at all at this point so I'm looking at Turbo so I can run the 31's at a later date. If the turbo doesn't work out I'll sell the damn thing and buy a Toy.
Honestly, after running a 1.3 with 35's for as long as I did I thought hell a fuel injected DOHC 2.0 should run 31's with 5.12's but nope..
Love zuks had them for years (thus the screen name) but I'm older now, I need to be able to enjoy what I'm driving end of story, hell Ive installed a full Navi/dvd/sat radio in this thing as well as a short block, suspension lift, body life 5.12's and a locker.. the trip home tonight was much better with the 235's but still hard for it to hold 75.. Think I may get a new timing set (sounds rattley) maybe the cam timing s off a tad?
Is there a way to check to make sure the base timing is good?
I'm rambling now so off I go..
