Looks like "limp mode" is more like 2200 rpm, I've posted the faults that trigger that on mine, should be the same for yours.
You need to get yourself a OBD-II scanner, perhaps someone here knows which ones to use but I think
ScanGauge is reputable. You need to make sure you have the right connector, below.
