Timing Chain Tensioner Design Flaw - Page 2 - Suzuki Forums: Suzuki Forum Site
Old 11-01-2006, 10:28 PM   #11 (permalink)
dick_morriss is on a distinguished road
Oh yea, dont know much about the 2.7 but everything we are talking about with regards to engine care certainly applies. It applies to any car really.
I wouldnt mind betting the tensioner is the same part. I do know that the part number of the no1 tensioner for my 2.0l is the same number as for the 2.5l
dick_morriss is offline   Reply With Quote Quick reply to this message
Old 11-02-2006, 07:24 AM   #12 (permalink)
XL7Limited's Avatar
Ill bet your correct. Same tensioner for the 2.0, 2.5 and 2.7..
Old 11-02-2006, 08:08 AM   #13 (permalink)
TimMcCabe is on a distinguished road
The current PN is 12831-85FA7, so it would have started as 85FA0. After about 85FA5, there has been no change in design, it's just been a change in PN to commonize use with other applications.
As we never had the 2.0 V6 in Canada, I can't confirm the PN, but based on the design, it's most likely the same as our 2.5/2.7.
The new design has a much finer ratchet, so it does not have to extend as far between adjustments. The net result is the chain does not have a chance to slap, which is what causes the wear and stretching.
Cheers,
Tim
TimMcCabe is offline   Reply With Quote Quick reply to this message
Old 11-02-2006, 05:23 PM   #14 (permalink)
Yea Tim, thats the part number of the tensioner I have here. Unfortunately I have just realised that instead of having 4 bolts going up through the oil pan into the timing cover, there is two bolts in the centre, and the two on the outside are studs coming out of the timing cover through the pan!!!!
Arrrgghhhhhh. TIme to take the sump off.
Now I am used to working on Alfa Romeo's which if you ever have worked on can be a real bastard, but I reckon the guys that designed the alfa must have helped the suzuki designers now!
Old 11-02-2006, 06:22 PM   #15 (permalink)
tmcalavy's Avatar
tmcalavy
Well I did the engine/oil flush with some stuff in a blue can, remember the old oil cans that required a church key?, that smelled suspiciously like acetone. Read the label and that's what it was, mostly, with some petroleum distillates thrown in. Think I'll try the ATF next time. I'll run it for a day or two, flush out the oil again and then try some genu-wine synthetic or synthetic blend. Any recommendations on that? My little 99 GV has a little over 106K on it.
Say Hello to my leetle friend!
tmcalavy is offline   Reply With Quote Quick reply to this message
Old 11-02-2006, 09:09 PM   #16 (permalink)
Dick,
Don't pull the oil pan.. Just double nut the studs and you can back them right out.
The same technique has been used since the Samurai to remove the oil pump
Cheers,
Tim
Old 11-03-2006, 06:21 AM   #17 (permalink)
Thanks for the suggestion Tim. Before I started taking the pan off I tried locking two nuts onto it but no luck. THey were no match for a pair of vice grips though.
The new no1 tensioner is the same in function, but totally different in design and geometry. The ratchets are the same spacing, but the new tensioner extends about 3-4mm further than the old one.
I sure hope this sucker fixes my rattle otherwise tools will be thrown ;-)
Cheers.
For those interested, have a look .....
Old 11-04-2006, 12:54 AM   #18 (permalink)
milbums's Avatar
milbums is on a distinguished road
Dick,
Its good to see someone else having as much fun with thier tensioner. I did my daughters a little while back. Here is a link to the thread and I put a little how-to together (its in my signature spot).
Joel
http://www.suzuki-forums.com/1g-2001...-adjuster.html
Timing Chain Tension Replacement Instructions
http://www.suzuki-forums.com/1g-2001...placement.html
milbums is offline   Reply With Quote Quick reply to this message
Old 11-04-2006, 06:31 AM   #19 (permalink)
Thanks milbums,
Yes I did see your excellent description of your tensioner repair. I wouldn't so much call it "fun" but more like "character building"!
The left hand rocker cover on mine was leaking at the back so had to take off the throttle body and inlet manifold to replace the seals. Pretty easy stuff luckily.
Did you find the old tensioner was a lot different to the new one you put in? Mine is out of a 2l 1995 motor so there is quite a bit of time between when that was designed and the current tensioner which fits all the suzuki v6's ( but not sure if it fits the latest grand vitara).
Old 11-04-2006, 01:40 PM   #20 (permalink)
sapien is on a distinguished road
Originally Posted by TimMcCabe
(or run a liter of ATF in the oil for a few days..).
does this really work? I was planning to run a can of Sea-Foam through when I reach 60K miles but I have some extra qts of ATF laying around
sapien is offline   Reply With Quote Quick reply to this message
Security Question
