Status
Not open for further replies.
Dash, HVAC and Shifter light bulb info...
1 reading
77K views 44 replies 12 participants last post by  moslem770
Noticed something odd during this morning's commute. The light behind my AC/defroster/fan buttons started dimming, seemingly at random, and clicking when it dimmed. Got almost to work and realized that it was doing this whenever the nose of the 99 GV 2.5 V6 2WD 4 door was not into the sun. Whenever I turned and put the nose/dash into the morning sunlight, the light clicked and returned to regular brilliance. Soon as I turned away from the sun in the parking lot at work it clicked and dimmed again, so I got out and checked the running lights...which were on. All other lights, instruments function normally when it does this. So, wazzup with that? Is there a daytime/nighttime sensor somewhere? First time occurrence...or at least the first time I've noticed this. I purchased it used in July with 70K miles on the odometer, now the odometer is up to about 115K. Would this set a code? Perhaps I'll put the code reader on it this afternoon. Any input is welcome.
#2 ·
Your about to have one of those Homer "D oh.." moments.
Your vehicle has auto on headlights if the switch is in the 3rd position. There is a little sensor on the right side of the dash. Block the sunlight from it, and presto, your headlights come on (and dim the dash lights).
Suzuki build a bit more delay into the newer ones, so that they don't cycle on and off as much..
Cheers,
Tim
"Doh!" Okay that's my Homer for today. Just to be clear, what is the third position? I keep my switch turned all the way back towards me. There are two other little icons on the switch below that. So which is the third position? All the way back...in the middle...or all the way forward? An aside here, dusted the dash before I left the parking lot at work and it didn't do it again...probably a dirty/dusty sensor?
#4 ·
TM! On a quick side note...do your climate control upper BUTTONS light up? Mine don't and it's a problem knowing what button to push or how to FIND the correct button when needed in darkness. The fan selector and temp lever areas are lit, but that's all at this end. :(
NE1 know what the "fix" is? Like individual bulbs are burned out, or ???
TIA
Save
Removal
1)Remove meter cluster hood 4 screws total, 2 right above your gauges (speedo/tach) and 2 in the corners to the steering column, tilt the wheel down and you can see them between the dash and column, then it should pull off may have clips holding it so be careful not to crack it.
2)Remove ashtray, center garnish and instrument glove box compartment.
There are 2 screws behind the ashtray and 1 straight up above the radio in the middle. then it will pull off might be clips there too so dont just pull hard.
3)Remove radio, clock or accessory case. 4 screws total, 2 per side. unplug the radio and antenna
4)Remove mode control switch with heater control panel from the above removed hole.
5)Remove heater control panel from heater mode control switch I think there are 2 screws on the back of this as well.
On the back of the panel there should be some caps that will turn a little bit and pop out thats where the lights are, I believe they are either brown or black I am unsure exactly as I have not had one apart for awhile.
if need be I may be able to get a few pictures when I have time, but not tonight.
#9 ·
tmcalavy: Not sure if your 99 is the same as my 2002, but my auto lights come on, even if i have my lights in the "off" position. (i only have the choice of: off, park, headlights). Thankfully the delay is longer, so they only usually pop on if i go in a tunnel or something. the only way to overide, is to partly bring the handbrake up, this disengages the auto feature, but only if u do it right from startup, or it doesnt work...:rolleyes: A royal pain of your at the `ol drive-in..^_^
Save
#12 ·
RallyRacer25,
You are correct, I was thinking of the newer models with the "AUTO" position on the headlight switch. The older models did not have the option of turning the AUTO feature off..
On the older models, if you unplug the light sensor on the dash, you will disable the Auto on function.. but the DRL will still kick on any time the engine is running, so you will still have to pull up the parking brake in the drive in.
Cheers,
Tim
#13 ·
Well we've got drive ins here in Tejas too. So, to recap, if I want to disengage my auto headlights I pull the emergency brake handle up a tad...before startup or after? My headlight switch has three positions, off, park lights and on. If I disengage the auto headlights this way will that stop the annoying dimming/brighting of the climate control cluster buttons? Not yet annoying but getting there.
#14 ·
i ONLY recomend using the handbrake if u r just putting around a short distance (ie moving from one spot to another in a drive in) DEfinately wouldnt recomend driving anywhere with the handbrake up, even a little bit, u will wear the rear drums badly, and will upset the handling of the vehicle. If you are having a persistant problem with it, then u would be better off disengaging it on a permanent basis, as Tim suggested. (ie pull the connection, or see if its running on a seperate fuse) and just use the lights the 'ol fashioned way :D Once u disengage the circuit that way, u shouldnt have ur interior lights acting up. The other solution, if u cant find the right connector to pull (im not sure myself) then u could always tape a piece of dark fabric over the sensor, so it stays in the "on" position, but have ur interior light dimmer turned up, so u can see the clock during the day. Does mean ur actual headlights will be on all the time, instead of just the day time runners... anyone else have any other ideas on this??
Save
#15 ·
Got the bulb out and it's bad (thanks Tech and Tim), but my local Auto Parts place says it's a dealer item.
The bulb is tiny, like a LED. It has two LONG leads (like an X-Mas tree bulb) that bends over on the bulb socket base to engage the circuit board. Had to reassemble the dash for now.
Tim...do you have the Suzuki part number asscoiated with the part #40 in the diagram that you provided in that earlier post? With that I can call around tomorrow (Monday) and find one. Maybe even find one on-line.
Thanks,
Save
#19 ·
Hi, I'm going through the exact same behavior right now, I need to change the light bulb on the upper part of my AC controls.
Could anyone direct me to the correct model in that website that is referred:
Autolumination Instrument Panel Light Bulbs & Lamps) or the equivalent that would work.
I got half way in disassembling my dash when I got stuck trying to remove the control like in this picture: and then I found this post, I stopped since I would need to get the special bulb anyway.
http://www10.plala.or.jp/jimnyito/irumi/0150.jpg
Any help would be really appreciated.
Regards
#20 ·
The best I can do is suggest checking w/the Suzuki Dealer (or GM / Tracker folks for that matter) to get the bulb.
That or the aftermarket bulb discussed earlier.
Save
#22 ·
Went to Radio Shack and bought the lights Fordem said about and took my dash apart. Sorry to say they are not right. Too small. I guess will go to the Suzuki dealer in the am. I talked to them the other day and they have to order it in.
Save
#23 ·
Re-reading this thread, I've just realized - I don't think the lights on my GV are lighting - I'll confirm that this evening and maybe take it apart on the weekend.
I'll let you know whether or not those bulbs do fit.
Well - I took my dash apart this afternoon - had nothing else to do.
Clap is correct - the RadioShack bulbs are smaller than the OEM lamp - but not too small, in fact, I have one of those bulbs in mine right now.
The biggest problem you'll have with the smaller bulb is keeping the green condom on - I superglued it to the plastic lamp holder with just a drop of glue so if I ever have to go in there and change that bulb, I can get it off.
1 - Remove the instrument cluster bezel - there are four screws, two above the cluster and two below (lower the wheel and look in the gap)
2 - Remove the radio bezel - there are three screws - two in the ashtray opening and one higher up.
3 - Remove the radio - there are four screws - should be visible after removing the radio bezel in step #2
4 - Unscrew the heater controls - there are three screws - should be visible after removing the instrument cluster bezel in step #1.
5 - Push the heater controls back and down into the space where the radio was - you should be able to reach the bulb through the space where the heater control was - it's a little circular black plastic fitting with a flat screwdriver slot - it needs about a 1/8 turn to release it.
Re-assembly is the reverse of disassembly, and yes, it is possible to push the heater controls back, even though it doesn't look so.
#24 · (Edited)
Was reading through this thread and I have a question. I saw the picture of the bulb with the long leads and read your description.....what do you mean by the leads bend over the socket base to engage the circuit board? No soldering needed? I can't quite visualize how the leads attach to the board.
#25 ·
Like in those tiny X-Mas Tree bulbs, where the physical contact / inserting them into the base provides the needed electrical contact. No soldering. ;)
You'll need to use the green cover from the old bulb, transferred to the new one is all.
Save
Status
You have insufficient privileges to reply here.
